Question about Energizer Eveready Utility Lantern Uses 6V Lantern Battery
On off wire in eveready 6 volt flashlight where to attach
The flashlight works but on/off button does not - unclear where to attach the wire
Our flashlight stop working even with a brand new battery
The bulb may be blown. If the bulb is ok then you may have a broken wire, corroded connections or a bad switch.
Jul 20, 2014 | Eveready 6V Super Heavy Duty Lantern...
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Change a 220-240v/28w/3500k light bulb
The question does not make sense since it doesn't pertain to the 6 volt dc flashlight
Jul 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Replacing a 6 volt battery
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
Jan 09, 2013 | Energizer Eveready Utility Lantern Uses 6V...
Wheres the expiration date on a eveready D battery?
Printed on the side or embossed on the bottom of the cell.
Apr 25, 2012 | Energizer Eveready TUF4D1E 4D Cell Lantern
I have an Eveready fluorescent lantern #9209. I can't figure out how to put the batteries in. I get the back compartment opened but am completely flummoxed after that. Does anyone have the instructions?...
On the bottom is an indention where the lamp attachs to the handle portion. The latch opens when you push the button toward the front of the lamp. Once it is opened, then slide the lamp off, revealing the battery compartment - remove the batteries and replace with new ones
Dec 28, 2010 | Craftsman Camping, Backpacking & Hiking
How do i open eveready dolphin torch for battery
You need to twist the black bulb end off in the direction of the arrow labeled open. The best way I found was to place the yellow end between my legs to hold it in place.
Sep 23, 2010 | Camping, Backpacking & Hiking
Eveready 6volt plastic flashlights do not work more than once.
Here in the UK I have never had much luck with flashlights (or torches as we call them!) stored in the car-exactly the same problem as you -the battery is always flat when you come to use it. I have even tried slackening the base off to break the contacts-makes no difference. Best to get a rechargeable one like this http://www.ebay.com/itm/2-pcs-15-LED-RECHARGEABLE-WORK-LIGHT-FLASHLIGHT-TOOLS-/330510652438?hash=item4cf3f85416:m:m9OEtxPyWSFj8nAyzf1i4Mw
Only downside is you can't leave this model on charge so if you can try to find one with a regulated power supply which can be left permanently on charge without damaging the batteries. Avoid the million candlepower ones too-yes they are very bright but only last 15 minutes on a charge!
Mar 29, 2017 | Energizer Eveready Utility Lantern Uses 6V...
Energizer Eveready Utility Lantern Uses 6V Lantern Battery Logo
186 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
NicK Hale
Level 1 Expert
Tom Chichester
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
