Question about Electrical Supplies
I have a Power Boss 7000 Portable Generator that runs well but does not provide electricity to any of the outlets.
This Generator is at least 5 years old and has never been used. I can't say with absolute certainty that it ever worked. I bought it at a time when I didn't need a generator -- i.e there was no emergency. However, knowing me, I am sure that after assembling it, I would have tested it to be sure it worked. So, I am pretty sure it worked at one time. The engine runs well. There is noe electricity from any of the 5 outlets. The main circuit breaker is on an I pushed the other two circuit breaker an sill no joy. Ther is an LED or lamp beside the outlets and I believe it is to let you know if electricity is available and it not lit. By looking at the generator vent holes it looks like the generator is turning. Do you have any suggestions on what I might check. The running meter shows zero hours on the meter. A helpful piece of information would be a source to purchase a maintenance manual. Thanks
  • 5 more comments
  • Ron Davis Oct 30, 2012
    I have found a source for a Generator/Inverter Repair Manual and it is on order. When I get the manual , I will update this problem.
  • Ron Davis Nov 08, 2012
    I solved the problem today and it was rediculously easy once some one told me how to proceed. It too 10 minutes.
    I said someone because I don't know where I copied this fix from. This is it and it worked. Something has come up and I must leave. I will complete this posting tomorrow.
  • peter_c_mori
    peter_c_mori Nov 15, 2012
    Ron, please finish this post, I have the same problem on the same generator
  • Ron Davis Mar 06, 2013
    I am very sorry that I never finished this posting. The solution is called "Flashing" the fields (restoring the Magnetisim) . The procedure can be found on ehow.com.Search for "How to Flash the Field of a Brushless Generator" It worked for me ONCE.I thought I was home free. This is a verycommon problem if you don't occasionaly start your generator an then put a load on it. I decided to start mine every two weeks or at least once a month. Two weeks later I started the generator and I had the problem again. I tried the Flashing procedure again and it didn't work. After a number of tries, I gave up. Since I had NEVER used the Generator, I went back to where I bought it and they were NICE enough to exchange it for a new but different one. I start my new one every two weeks,
    I hadn't finished my recent comment and made the same mistake I made before -- I hit the return key. The procedure is also called "Exciting" a Generator. Go to ASK.COM and put in either phase and you will get numerous responsses..The ehow.com procedure is the easiest if you have two drils.
    This problem is closed for me.
CarlGehrke
  • 169 Answers
SOURCE: Hello Tech Team: I own
Wow, you've got an ugly problem. It sounds like you already know that you have to pretty much disassemble these little buggers down to the frame to see anything inside, so I'll say what to look for:
1 - Burned wires in the part of the generator that doesn't move. This is the bit that carries the current shorted out by the mud.
2 - Burned wires in the part that does move. This is the bit that makes the magnetism that makes the electricity. There are also some diodes and MOVs tucked into the end of the plastic insulator
You're likley better off getting some other generator, sorry.
Posted on Nov 29, 2008
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
SOURCE: portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Posted on Mar 16, 2010
  • 342 Answers
SOURCE: Briggs and Stratton 8500 HP generator with only .4
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Posted on Apr 04, 2010
  • 13 Answers
SOURCE: I have an overload alarm on my honda eu2000i
it may be a thermal coupler that cuts out when it gets to hot i would let it cool off for a bit then try it with a lighter load and go from there
Posted on Jul 28, 2011
How to find portable generator brands?
There are numerous sites online that are providing specifics of portable generator. These are typically specially manufactured for those people who are looking for good quality portable electrical generator and it's assessment. To find out more please click here.
Best Selling 2000 Watt Portable Generator Brands 2016 Top Brands Guide
Aug 05, 2016 | Electrical Supplies
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Gentron gg3502d outlets have no power
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
May 24, 2014 | Gentron 10,000W Generator with Electric...
Sigma 6500E generator
Mar 20, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
No power
Mar 19, 2014 | Hyundai HY1000si 1000W Portable Inverter...
Onan 7000 generator runs but does not produce electric to rv
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
Will not generate electricity
Mar 09, 2014 | Coleman Powermate Subaru 5000W Portable...
Titan generator Manuals
Can you please provide more information
Oct 05, 2010 | McCulloch FG7000MA 7000 Watt 13 HP 389cc...
My generator runs but doesnt put out to the electrical outlets
You may have to check the wiring, With the engine off check the following: they may be a loose wire, the brushes on the generator may be too worn. Check for continuity from the outlet all the way to the generator.
Jun 06, 2010 | Porter Cable 6,500 Watt Contractor...
Electrical Supplies Logo
417 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
