Question about Honda Eu2000i 2000w Generator
Honda eu2000i eco mode troubleshooting. I took the carb off, cleaned it, put it back and it runs fine, but won't go into eco mode. I have two of these, did the same to both and the other runs fin
As I stated, I cleaned carbs on both of my 2000 gens, but one won't go into the ecomomy mode. Otherwise it runs fine, just won't slow down with no load on it.
RJones1125
  • 373 Answers
SOURCE: my honda crf100 will not start i have change the
it the bike has been sitting for a long period of time. the carb. can gum up. pull the carb. off. clean it up really good. insuring you get all the small ports clean. then try it again.
every dirt bike i've had requires a oil wetted air filter. dont forget about that.
Posted on Feb 23, 2009
Mitchy123
  • 216 Answers
SOURCE: 2006 honda shadow 600 backfires through the carb
Sounds to me like your running too rich, IE - theres too much fuel being burned as opposed to air. I'd check and make sure your airfilter isnt dirty, anything that restricts airflow can cause this. Dont leave the enricher on once the bikes started up...make sure you have the right plugs in there
Posted on Mar 19, 2009
  • 212 Answers
SOURCE: 8 hp honda on cement mixer starts on first pull but shuts down as if it is running out of gas. I put fresh gas in it and cleaned the filter and bowl of the carb.
if it has a fuel filter. check that. change the spark plugs.
Posted on May 24, 2009
  • 76 Answers
SOURCE: have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Posted on Jan 29, 2010
SOURCE: Honda generator eu2000i will only
clean the carb again and blow all passages with air. make sure the harness to the carb is all the way plugged in.
Posted on Oct 28, 2011
2000 gsxr600y Flat spots and rough running at 8 and 11 thousand rpm, won't pull passed 11000 from 4th gear up as running so rough
Full disassemble of carbs is needed. Thorough cleaning on jets and airways, vacuum and pilot screw adjustment must be done too.
Check the spark plugs for lean mixture indication and replace them if necessary.
Oct 20, 2012 | 2000 Suzuki GSX-R 600
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
2000 Yamaha WR400 wont run with choke off.
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
WR400 won idle choke
Help 2000 wr400 won idle off choke What could it be motorcycles
YAMAHA WR426F Owner Service Manual
OEM parts for Yamaha
YAMAHA WR450F Owner Manual
May 19, 2012 | 2000 Yamaha WR 400 F
I HAVE A STIHL FC-44 EDGER, WON'T RUN, HOW DO I CLEAN THE CARBURETOR AND WHAT ELSE SHOULD I CHECK? THANK YOU
@ Curtis I beg to differ Sir.You state "ALWAYS USE COMPRESSED AIR". Not so fast. High psi air can and WILL damage the sensitive check valves in the carb (esp if the Low and High speed mixture screws are removed). They do not like the ethanol as it is...high psi air is adding insult to injury.
Apr 15, 2012 | Garden
I have a 2 cycle Troy-Bilt line trimmer. I've had
Sometimes, unfortunately, the chemicals and solvents used in a "dip" and/or cleaning solution are too harsh. They tend to "swell" the very sensitive check valves inside the carb. The idle fuel circuit has one, the high speed main nozzle has one, and there are one or two inside the primer pase assembly on top of the carb. You state that it won't idle, but does it run otherwise. If it does, some carb adjustments may be required on the L and H screws to get it to idle.
Sep 09, 2011 | Troy Garden
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
'83 virago xv500k starts right up, runs solid, but
the fuel tap may be causing to problem, if it doesnt turn off it can also flood the engine over night and allow fuel into the sump which then vaporises as it gets hot and the breather allows this fuel back through the air cleaner causing rich mixture
May 07, 2011 | Yamaha yZFR125 Motorcycles
My bike will idel but won t rev. just cuts off
Starving for fuel.
Make sure carbs are getting fuel.
Make sure fuel filters are clean,
make sure fuel pump is working.
If carbs are getting fuel but wont rev, you need to clean your carbs because your jets are clogged
Dec 03, 2010 | 2000 Suzuki GSX 750
Generator not running for about two years,clean plug,but gen. won't fire up spray carb cleaner & runs for a few sec. & quits
Hmm sounds like you may have some clogged jets in the carb. You might want to take this to a professional and have the carb cleaned.
Aug 20, 2009 | Electronics - Others
Honda Eu2000i 2000w Generator Logo
78 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
