Question about Cub Cadet Garden
Will not pull on incline
Runs and mows good on flat ground ,very weak pulling on incline
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Hydraulic pump belt needs adgusting or replacing
Posted on Nov 22, 2013
5 Suggested Answers
  • 313 Answers
SOURCE: Riding lawn mow
give as the model so we can help.
Posted on Jun 12, 2008
  • 138 Answers
SOURCE: I have the same ,Sears Kohler tractor won't pull uphill
Have you checked the fluid level in the hydro trans, there is a drive belt from the engine to the hydro trans check and make sure that this is not worn or loose. Make sure that when you check the tension of this belt that you do not have the engine running or the parking brake set, since tension will be released from the belt when parking brake is applied. good Luck
Posted on Oct 07, 2009
  • 3911 Answers
SOURCE: Runs fine on flat ground will not pull a hill
Sounds like you could be running on one cylinder. I assume you have a two cylinder B&S, Tecumseh, or Kawasaki. Remove one spark plug at a time and try driving the mower. If you have nothing on one spark plug and drives exactly the same with the other, then you have a dead cylinder. Can be a spark problem, unlikely a fuel problem assuming a single carb, a bad head gasket, bent push rods. A lot of B&S Vanguard engines, including mine, have a tendency towards bent push rods.
Posted on Oct 20, 2009
  • 10 Answers
SOURCE: husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Posted on Jun 23, 2012
Testimonial: "thanks for the info. we had the schematic belt is on correctly, all he gears in the transmission looked really godd and clean no metal fragments when we changed the axle. any other ideas, thanks"
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
L120 cuts great but wont pull up a hill
replace the drive belt .they do wear out
May 07, 2016 | John Deere L100 Series
Sears lawnmower kills after mowing for 10 minutes doesn't restart till rested a long time. Repair man says nothing wrong with it.
That is the symptom of a failing ignition module. With the airbox cover and air filter removed run the unit till it fails. Immediately squirt a shot of carb cleaner into the carb and try to restart. If it restarts see if you can keep it running on the carb cleaner for a few seconds. If it wont restart or stay running then its likely an ignition module. If it does restart and keeps running on hte prime then you have a fuel issue.
Other things to check: spark plugs can fail when they get hot, checkt o make sure the engine stop cable is pulling the bail off ground sufficiently. If the cable has stretched it may not pull the bail completely off ground causing intermitent spark.
Nov 17, 2012 | Garden
Husqvarn lgt2654 wont pull
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Have a 48' 23 hp husqvarna lawnmower, it drives fine, but when I go uphill it slows down quite a bit. Why?
Same reason a person slows down when he is riding a bicycle up a hill?
Does the engine nearly die when you engage the blades on the fly?
If so you may have a dead cylinder, my 2148 would mow on the flat pretty well but not an incline with one cylinder. Cause of my dead cylinder was bent pushrods, which is not unusual on V-Twin B&S. You can test this by pulling one spark plug wire off at a time and running it.
Mar 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
GSXR 400 rev problem
The float level in your carb probably needs to be adjusted. If the gasoline level in your float bowl is borderline low, your bike may run fine when level. But on the incline, the gas level at the jet may be too low causing your engine to be starving for gas. The solution is to remove the bowl and bend the tab on the float that pushes the valve up so that the gas won't shut off until the level is higher. If you are a good mechanic, you may try this yourself. If not, take it to someone who can do this for you.
Nov 04, 2009 | 1998 Suzuki GSX 400 Impulse
My 88 ramcharger runs smooth but no power. does 75 mph on flat ground but any incline or from a stop nothing
Is your kick-down linkage working correctly? They have a hard time pulling their weight without it. Check out a thread search or post a request for help on the vehicle board at Ramchargercentral.com...the members over there are great and will help you get it diagnosed.
Jun 08, 2009 | 1988 Dodge Ramcharger
Garden Logo
57 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
