Question about Lexmark Optra T610 Laser Printer
Service 935/933/934 printhead error lex optra T610
I don't speack englisgh i'm brasiliam off the from Brazil
2 Suggested Answers
  • 85 Answers
SOURCE: optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Posted on Mar 13, 2009
I want to change language - lexmark optra t610 printer
You can change the language on your Lexmark Optra T610 by pressing right arrow Menu button 6 times -> select Printer Language (first option to appear), hit Select -> select preferred language, hit Select button to save.
Hope this helps. Thanks.
Nov 10, 2010 | Lexmark Optra T610 Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
Optra T610
If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
May 01, 2010 | Lexmark Optra T610 Laser Printer
Invalid engine code on Lexmark Optra T610
Sounds like you've experienced a fairly common problem with Lexmark Optra printers. The engine board has more than likely failed. Rather than go to to Lexmark, try this site for a less expensive replacement board...
http://www.partsnow.com//
Apr 19, 2010 | Lexmark Optra T610 Laser Printer
935 service printhead error
hello
check this link out
you will get aal the answers for all the printer issue s
http://www.all-laser.com/cgi-bin/webc.cgi/error_lex.html
let me know if you need any assistance
Mar 08, 2010 | Lexmark Optra T610 Laser Printer
I am getting a 922 Service Fuser Error what does that mean?
a 922 error means that the ac circuit is open. this is the heat lamp circuit. a burned out bulb, blown thermal fuse, or pitted contacts will be the cause. replace the fuser and your back up and running
Oct 06, 2009 | Lexmark Optra T610 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
Optra t610 error 935/933/934
Jan 03, 2009 | Lexmark Optra T610 Laser Printer
LEXMARK
That error indicates that you need to replace the Engine board. The part number is 11K1416, a service tech would need to replace it due to settings needing to be reset.
Jul 15, 2008 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 Laser Printer Logo
766 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
