Question about Dorcy International p6V Floating Luminator Lantern with 6V HD Battery
How do you install 6V battery into Dorcy luminator
I put new 6V in but it won't screw on right? I forget how old battery was positioned. How do you screw lid back on ?
I was just having the same problem - I didn't realize that I had to take the black caps off the two springs at one end of the battery! Once I pulled those off, and put the battery in with the springs facing up, I was able to screw the top of the flashlight back on, and it worked. I hope this helps.
Posted on Feb 08, 2013
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
Trying to remove the lid from a toshiba c660
The lid has to come off. Make sure you remove the strip that is right above the keyboard so that you can get to the screws that hold the lcd in place. Also remove the screws on the bottom of the laptop that are right under the lcd screen. Sometimes there are screws on the back side of the lcd screen that have to be removed.
Apr 26, 2012 | Toshiba satellite c660
Washer won't spin
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
First open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
Also check this link to get a detailed idea related to your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query or else please accept the solution.
Sep 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I've put in new batteries and it doesn't turn on.
some P touch series had trouble with the lid not closing, or seating, and some may not have the batteries inserted the way that is logical. check the battery polarity one by one and make sure that they are going in in the right position and order. then make sure the tape is in right and seated and that the lid closes. if all these don' t solve it take it back and get a new one as there is not a reset that I am aware of. Check your specific model for a small reset round hole on the bottom just in case and try the manual. http://www.ptouchdirect.com/ptouch/manual/PT1880.pdf
Jun 13, 2011 | Brother P-Touch PT-1880 Printer
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
It does not spin - error
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
May 03, 2011 | LG Washing Machines
Where and how do I replace my battery for my pride gogo ultra travel scooter
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Feb 24, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Dorcy International p6V Floating Luminator Lantern with 6V HD Battery Logo
1,465 people viewed this question
Top Dorcy International Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Dorcy International Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
