Question about Frigidaire FEF364DQ Electric Kitchen Range
Cfes365 new dual element is different from old and the wiring connections are different
I am replacing the RF element and the new one has a different layout, I double checked this with the supplier and they confirmed that this is the subbed part. I dont want to fry the element or oven by putting it in wrong. Any suggestions?
  • 87 Answers
SOURCE: oven heats up very slowly and does not get very hot
Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
Posted on Jun 08, 2007
  • 1314 Answers
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
Posted on Feb 13, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
  • 2976 Answers
SOURCE: bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Posted on Mar 16, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
I just replaced my old rusted out water heater with a new Reliance 606 and now I am having problems with the circuit breaker being tripped, usually during the night. It doesn't happen everyday but is...
I would check with your owners manual to see what they reccomend for minimum breaker size. I don't remember on this particular model but it may be a single element instead of dual element. The single element usually use more power than dual. I would also check thermostat settings if this is a dual element. They should never be set at same temperature. Also if it continues to trip breaker I would check all wiring,then replace breaker. Sometimes they do wear out and trip when they really shoul not. Hope this helps. Thanks
Nov 15, 2010 | RELIANCE ELECTRIC WATER HEATER
Hob regulator wiring
OK, they are wired so that the two elements are switched in and out, to form, a single, a dual but in series, and a dual, but in parallel. like this Low, ONE, Element ONLY, The Other is out of circuit. Med, TWO elements are connected using the switch, in SERIES with each other. High, you switch TWO elements in PARALLEL. Simply meter the switch out to do that when each position is turned. Just think of it like, It's just two resistors, wired up. single, series, & parallel.
Apr 19, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
My 10 year old Kitchen Aid convection smooth surface range has a broken dual element switch on LF element. My Canadian Whirlpool contact provided a replacement switch # as 8203538, which I purchased. The...
your model calls for the pt # 8203538 and is a good # the sw 688 may be alright but I would use the 8203529 / this is a 15 amp sw. and is the correct replacement .it's blue in color and comes with instructions to install . . we use this sw alot and it does not cause porblems . / you should ck other things like tight connections at the power cord as loose or bad wire connectons will burn out the sw . ck all the wire ends for discoloring and if so replace them with hi tempt crome ones . they work best .. hope this helps **** .. .
Jan 10, 2010 | KitchenAid KERC507 Electric Kitchen Range
One of element of dual elements doesn't work.
Dual element has a common "return" wire but separate hot wires... Could be a burned element or a bad connection to the second element. REMOVE THE POWER before checking the element wires (for safety) .
A bad connection will be obvious. A bad element will not be obvious - but they are not very expensive.
Replace the element if the wiring looks good.
Jan 08, 2010 | Kitchen Ranges
I am doing a custom harley project,bobbed fender.. I want to use dual filament stock lights and I want to use them as run/turn/brake lights, I tried several different things and cant seem to get it right...
This is a standard set up for (old school) lights on about any car from the 50's 60's 70's see how they are wired. . Look at a wiring diagram for say and old ford Mustang The old style bulbs like a 1157 (I think) use a dual element. The base is the ground, the brighter element is the turn/brake and the dull filament is your run. To use one bulb here to do both turn and brake, your turn has to be the predominate order, in other words the turn will have to over ride the brake light or turn it off. So the only new school thing you might need will be a Diode on your hot (brake) wire to the bulb. So you will have two wires to one terminal of the bulb. The brake circuit will need a diode -|> and it will also connect to the same term as the turn circuit. The run will be alone circuit on the bulb as the ground wire. 7ce0811.gif
Jan 01, 2010 | 2002 Harley Davidson FXD Dyna Super Glide
Hi there, we have replaced dual infinite switch on our jennair range and cannot figure out the correct wiring for the new 12002125 switch....can you help...???
Follow the instructions below from partselect:
Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1. Also attach the jumper cable to P1 and "jump" it to S1.
Attach the orange wire (old switch terminal 5) to S2
Attach the yellow wire (old switch terminal 4) to 4a
Attach the tan/(white?) wire (old switch terminal 3) to terminal 4 on the new switch
Attach the single red wire from the right front element to terminal 2 on the new switch.
Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
There is no need to separate the compound red wires.
Best regards.
G.
May 28, 2009 | Kitchen Ranges
Need to replace broil/bake element wiring
as a repairman this is what i would do.because if you just but on a new connector on and its not super tight it will burn there.loose connection draws maximum amperage.so i would carie with me spares wires that i cut off from old ranges.they would then have a factory tightened terminal at the applied end and i could wire nut on the other end with good confidence.with that said find a used stove and cut the wire off to the element with six to ten inches and splice in ,it will be fine if connections clean tight.also protect wire nut from heat[black tape up] that might seem hokiee but it works and cheapest /fastes.new/old wire must have connector that will apply to your element.hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings.thanks
Jan 06, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I want to replace an erratic element on a really old Viking stove. The new element plugs into a new recepticle,but the latter has 2 wires, whereas the old stove has 4 wires that were connected directly...
This can't be done. The old elements were a two part element with 2 seperate coils. The heat was controlled by using one or both elements at different voltages to select the heat output. The new 2 wire element just pulses the current on and off to control heat. It is just one big element. Try to purchase a generic replacement burner that will fit the hole. Usually these come with the chrome ring and everything. They are somewhat adjustable but will not match your existing burners. GE used to make this. Another possibility is if the control to the burner is a knob that turns, Replace the switch with a new infinate heat switch. If this switch will mount properly. Just grab the two 220 volt legs from the old switch, Ignore and tape the neutral, ground, and pilot leads. Connect to the line side of the switch. Use only 2 of the old wires going to the burner and connect them to the new one.
Jun 29, 2008 | Kitchen Ranges
Frigidaire FEF364DQ Electric Kitchen Range Logo
99 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
