Question about Casio fx-300ES Calculator
How to turn off sci mode - Casio fx-300ES Calculator
  • dsad Oct 29, 2012
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press SHIFT [MODE] then select either 6 followed by a digit or 8 followed by 1 or 2 to select either fixed decimal or normal display mode.
If you need a manual, you may download a copy here.
Posted on Oct 29, 2012
How to cancel fix mode
If your calculator has a mode key, try pressing it repeatedly and see what is displayed. If you see FIX, SCI, ENG, Float or NORM, press the key corresponding to float or Norm (if there is no float).
If your calculator has a key next to which is the FIX marking, look around to see if you can find SCI, ENG, Float or NORM. Select Float or Norm
Jul 30, 2012 | Office Equipment & Supplies
How do I turn off the SCI mode?
Press SHIFT MODE to enter SetUp and select another display option: Normal or Fix.
Sep 09, 2011 | Casio fx-300ES Calculator
How can i get fix off my calulator
To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
Jun 23, 2011 | Casio FX-300MS Calculator
HOW CAN I GET FIX AND REG OF MY CALULATOR.I AM USING FX 300MS.
Press MODE 1 to get out of the regression mode and into the standard calculation mode.
Jun 23, 2011 | Cameras
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Mar 03, 2010 | Casio Office Equipment & Supplies
I just wanted to know if there is an engineering key or function like sci on the fx115 es casio calculator
SHIFT MODE 7 for SCI and SHIFT MODE 8 for ENG. Each of them needs to be followed by a digit.
Mar 02, 2010 | Casio FX-115ES Scientific Calculator
How to get it out of Sci math
To get out of the default MthIO press [SHIFT][MODE][2:LineIO]
To get out of Sci display format, press [SHIFT][MODE][6:Fix] followed by a number between 0 and 9, that will set the number of decimal digits.
Hope it helps.
Thank you for rating this solution.
Dec 04, 2009 | Casio fx-300ES Calculator
How to switch off the REG and Sci function
press MODE then select CALC then COMP to remove REG.
press MODE again select DISP then NORM1 to remove SCI.
May 20, 2009 | Casio FX-115W Plus Calculator
Turn off sci
To turn off SCI, press the MODE button, then press 9. MODE 9 is the function for NORM, which means normal use. DEG is always on, but if you want to clear SCI or FIX, MODE 9 will clear these.
Nov 19, 2008 | Casio FX-250HC Calculator
Problem withi scientific calculator
How do I get rid of the word "Fix" from the calculator display.
Jul 25, 2008 | Office Equipment & Supplies
Casio fx-300ES Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
