Honeywell t6661d not working, flame shows but radiators cold
I have a Honeywell t6661d thermostat. For some reason the flame comes on but my radiators are cold. Thanks
SOURCE: Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Posted on Jan 23, 2008
SOURCE: changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Posted on Feb 16, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: How to lock a Honeywell TB7220U Thermostat
With directions go to system. Then hold down 2 blanks on either side of middle for 30seconds this shows you Advanced settings . Read through and find the proper settings
Posted on Jul 04, 2009
  • 252 Answers
SOURCE: how do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Posted on Oct 10, 2009
My Honeywell dt200 is displaying a flame when I turn it on but isn't actually heating.
The problem could be with the heating unit or furnace and not the thermostat.
Aug 10, 2015 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat for gas fireplace not working
sir there is some probalm in LED change it for use
Jan 25, 2014 | Honeywell Heating & Cooling
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell Thermostat CM67NG The flame symbol is showing on the thermostat, but there is no heat from radiators. The status code on boiler says there is ' no heat demand'. Boiler shows radiator...
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Nov 30, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
