Question about Tanita BC-534 InnerScan Body Comp Scale
Need to reprogram my age and activity level
Please advise on how to reprogram my scale to reflect my current age and acitvity level
Col
  • Anonymous May 25, 2009
    this link is bad
  • 10,865 Answers
Www.tanita.com/manuals/BC-534(1)_manua.pdf
go to that address and download the manual for free. it will tell you how to reprogram the scale.
Posted on Feb 14, 2009
  • paigesass
    paigesass Feb 04, 2012
    no it only says how to do the initial programs, not how to change or update
I need to activate gprs settings on samsung galaxy y s5360 by uninor sim
Do this to acitvate for smart Internet
Rename Profile: SmartGPRS
APN: smart1
Server: http://wap.smart.com.ph
Proxy: 010.102.061.046
Proxy Port: 8080
Username: leave it blank
Password: leave it blank
MMSC:http://10.102.61.238:8002
MMS PROXY: 10.102.61.46
MMS PORT: 8080
MMC:515
MNC:03
Authentication type:PAP
APN TYPE: internet+mms
Mar 03, 2012 | Cell Phones
Tip
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | Computers & Internet
How do I change the age on my healthometer scale, model BFM676KD01
Press Left "Select" key; Press Right "Scroll" Key to select USER (Digital Display flashes to show USER #); Press and HOLD "Select" Key until "Height" flashes; Press "Scroll" to advance Height '; Press "Select" to move to next input. When "Age" flashes, press "Scroll" to your age, and you're done!
Nov 17, 2011 | Health & Beauty
Describe your prodex error solution DJ165E Problem my age and height appear then its 00 i stand on the scale then it says 1 2 3 4 Err
You need to have bare feet as it is trying to measure fat/hydration/muscle ratios with a current. If you have socks on or anything there to impede the current from metal areas on the top of the scale and your feet it will error out. Hope this helps.
Feb 21, 2011 | Health & Beauty
Change settings. model #2202/UM-016 I have lost the directions and can't figure out how to change my persona settings. In an attempt to change my age I changed my *** and can't change it back.
I searched into this site with the same problem, how to update/reprogram the UM 016.
I figured out how to do it, shame there\'s no mention of updating memory data in the Tanita literature.
Assuming scale has batteries and old settings.
Press \'set\' button instead of memory or guest. The \'1\' memory should appear and blink. If you want to reset the \'2\' memory, press up key until the \'2\' appears and blinks, then press \'set\' again.\'
When you press \'set\' while the memory location is blinking, you should be able to page through and change the age/height/sex settings for the scale memories. When you are done, the scale will eventually shut down, saving your new settings, which you access with the \'up\' button when you want to use the scale.
Oct 19, 2010 | Tanita Digital Body Fat Scale with 2...
I have Nissan Altima with incorrect guage reading
The Correct Rerpair for this to to REPLACE the FUEL LEVEL Sending UNIT. It is Located INSIDE the Fuel Tank, After Reserching this through Numerous Resources I Have Fould that it is Incorperated into the FUEL PUMP. So You can Use your Current Calibration Method or Replace Fuel PUMP. Looking at the Vehicle AGE and IF IT HAS OVER 100K Miles on it , It is Advisable for you to Replace the INTIRE UNIT. It is OBVIOUSLY Not Manditory as the Vehicle is RUNNING, But If you Wish to Have Accurate FUEL LEVEL Reading Replacment is the ONLY OPTION.
Sep 01, 2009 | 1997 Nissan.5 Altima
Digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
Aug 27, 2008 | Detecto 253 Baby Scale Mechanical Infant...
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Tanita BC-534 InnerScan Body Comp Scale Logo
475 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
