Question about Euro-Pro Ninja 1100 Nj602 Blender Dough Maker W/dough Attachments And 6 Blade System
Power light blinks but power wont turn on - Euro-Pro Ninja 1100 Nj602 Blender Dough Maker W/dough Attachments And 6 Blade System
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Wont turn on,just blinking light
This will probably need either a new thermal fuse on the field windings or a new motor.
Nov 17, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Ninja blender second time we have used it. the power light is blinking when you push it and the blender will not turn on
Put the lid on so the arrows meet up. There is a arrow on the lid and handle put them to gather and blend!
Jul 14, 2011 | Blenders
Power light blinks and blender won't turn on
Probably just a fuse. Also try a different outlet. Check the manual for fuse location and other possible solutions.
Download Cuisinart CBT 500 Manual at Bob Manuals
Apr 11, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
Cusinert blender
I had the same problem and I manaed to fix my Cuisinart SmartPower Duet blender. There are two thermal fuses, one tape attached to each stator winding. Both of mine were blown.
In addition, when the fuses blew, it must have spiked the triac. I had to replace mine. It's the black 3-legged transistor looking device with a small metal heatsink attached to it. This gizmo directly throttles the power to the motor under control of the microprocessor. There are some guides on the internet on how to test it.
Also, the clutch was very hard to remove and needs to be removed to more easily replace the thermal fuses. I clamped down the end of the motor shaft to a bench vise real hard and then I used a 7/8-inch open-end wrench to wedge into the clutch prongs which made it much easier to apply torque. Remember that its screw threads are reversed from normal screws so that it does not unscrew during operation. You have to turn it counter-clockwise to unthread it.
Hope that helps!
-Vince
Sep 13, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Cusinert blender
you most likely have blown the thermal fuse. I just fixed my blender which had the same problem but only after I bought a another base:< If you are a handy person, it is a very simple fix. buy a 10 amp thermal fuse from "RadioShack" for $1.69. Sadly, it is cheaper to buy a new blender than have it fixed at a repair shop.
Mar 19, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
Aug 14, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Euro-Pro Ninja 1100 Nj602 Blender Dough Maker W/dough Attachments And 6 Blade System Logo
55 people viewed this question
Top Euro-Pro Blenders Experts
spy1309
Tom Chichester
Kolbrun...
Are you an Euro-Pro Blender Expert? Answer questions, earn points and help others
