Question about Husky Electrical Supplies
Husky 5000 generator will not start
Husky 5000 generator has fuel and oil but will not start. I positioned the on switches to on and cranked the starter but nothing happens. Is it possible that I overchoked the engine?
  • 7,482 Answers
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 29, 2012
SOURCE: checking oil in generator
I found some website help. I have this same problem.
http://www.powermate.com/faq.php?cat_id=3
http://www.powermate.com/faq.php?cat_id=3&faq_id=32
I also found out a lot about the Powermate company via a customer service email reply: This has an elusive customer service number that i have not tried yet.
Powermate Corporation is not a part of The Coleman Company, Inc. They have been an independent company for over 10 years and we have no information on their products.
Powermate manufactured generators, pressure washers, air compressors and air powered tools. Information about those products was available from
Powermate Corp.
125 Airport Road
Kearney, NE 68848
Toll Free: 1-800-445-1805 (disconnected)
or 402-758-6303 (disconnected)
Web Page: www.powermate.com
Earlier this year, Powermate transferred the right to sell air compressors and air powered tools to a company by the name of MAT Industries, LLC, 625 Barclay Boulevard, Lincolnshire, IL 60069, 1(800) 628-8815. This company may be able to help you with questions related to air compressors and air powered tools.
In March 2008, Powermate filed for bankruptcy protection. We understand that customer service inquiries to Powermate via emails, mail and telephone calls will not be answered. However, some information about Powermate and its products continues to be available at their website.
If the problem with your unit is with the engine, check the engine manual that came with the unit to determine whether the engine has a separate warranty from the manufacturer. When Coleman was affiliated with Powermate, they did. If so, you can contact the engine manufacturer for a listing of warranty centers in your area. The contact number should be in the engine manual.
If you are needing parts for a powerwasher, please visit the site
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts for assistance.
Thank you,
Harold
Coleman Consumer Service
Posted on Sep 02, 2008
Pyrhyc
  • 2028 Answers
SOURCE: coleman powermate 6250 generator will not start
I have one of these generators, and I can tell you that at least once a year, I have to pull the petcock type assembly off tank, and clean it. I also drain and clean the tank. It gets a sediment build up, and the petcock system isn't the greatest in the world. I'm going to say that you either have a problem in the petcock type assembly, or you have a stuck jet in the carb, either of these can happen with it sitting for the long period of time. Start by removing the fuel line to the carb and checking the fuel flow. Sounds like you may have already done this, I'm unclear on that. Then I would remove the carb, and soak it overnight in a penetrating oil. This will loosen up any rust or parts that may be sticking. One other thing you may consider, depending on where you live, you may have a mud dauber or wasp nest in the intake or other critical area of the engine. I still get amazed at where I find mud dauber nests occasionally, the little buggers seem to be able to get anywhere.
Posted on Sep 05, 2008
CarlGehrke
  • 169 Answers
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Posted on Dec 15, 2008
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
My RV has a Onan Emerald 5000 Genset Generator. I will start it and it will start after 3 times cranking it. Runs fine. Turn it off. Then try to start it again and I get nothing. No trying to crank.
associated problems here are
low oil sensor system faulty
fuel flow insufficient-- blocked fuel tap /filter in tap
problem wiring in the coil area--stop switch
problem ignition control module
take it to a generator repair shop/ mower repair shop for a proper diagnosis and quote
Sep 06, 2016 | Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
5000s diesel will not start even on ether
mmost engines have a low oil switch. if generator is not level or it is low oon oil by just a little it will not start hope this helps bob
Mar 04, 2013 | Pramac Diesel Generator 5500 Surge Watts,...
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
It starts with the switch fine but when i let go of the key it cuts off
Check for faulty low oil sending unit or oil level low or dirty oil (some generators have a fuel cut-out solenoid at the carb ). Key switch will override the low oil safety. Easy test, remove wire from oil sending unit. If unit runs, and oil has not been changed in a while, service engine and retest.
Sep 09, 2011 | Mi T M MiTM Generator 9hp Honda 5000 Watt...
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
Jul 26, 2010 | Watts Onan Portable Generator - 5000 ,...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
3,187 people viewed this question
Top Husky Electrical Supplies Experts
Jim Goldsmith
Jim Goldsmith
JOHN LAPIER
Are you a Husky Electrical Supply Expert? Answer questions, earn points and help others
