Question about Iview 352PTV TV
Iview 2200 led tv
I have a iview 2200 led tv and i need the code for a ge remote plzzz help
    Sergeant:
  • 214 Answers
If it's a GE universal remote and it doesn't have the brand name iview in the manual with the code then you can't use the universal remote with it. I also have a GE universal remote and no matter which model of GE remote you get they have the same codes. I have never heard of iview so I doubt it will work. You can try and see if there are any original remotes for the iview on ebay though.
Posted on Nov 03, 2012
Rca remote rcu 450 need TV codes for iview 2200 led TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Oct 11, 2016 | RCA Televison & Video
GE universal remote code for a Funai LED TV. please can anyone help? Need the code for the above TV
0042 0076 0094 0601 0616 0654
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
May 02, 2015 | GE Televison & Video
TV code for a iview 2200 led tv
Check these codes. 0034.0059,0024,0267,0375. If you wish to get more codes, check this link.
Feb 12, 2013 | Televison & Video
How can i program an GE universal remote to a iview dvd player
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 07, 2012 | Televison & Video
Need a code for GE tv urc 3021 remote can u help
Here are the GE TV codes provided in the manual: 0047, 0051, 0451, 0178, 1147, 1347
To Program the Remote follow these steps:
1. Turn on a desired device you GE TV.
2. On the remote control, press the TV key once
3. Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until you find one that works.
6. Repeat steps 1 through 5 for each device you want to control.
Here is a link to a pdf. of the Remote's Manual:
http://www.retrevo.com/support/One-for-All-URC-3021-Universal-Remotes-manual/id/2784bh227/t/2/
Hope this helps
Aug 21, 2011 | One For All URC-3021 Remote Control
I have a sylvania tv and need the codes for my ge universal remote RC24914-E tmurra8@twcny.rr.com
This remote uses a 4-digit code.Try one of the following codes: 0062 0004 0009 0135 0189 0183 1141 0227 0456 0008 0068 0075 0141 0161 . There is also a manual code search available.
With the TV on, press and hold Setup until the LED lights up, then release Setup. Press the TV button once (the LED will blink). Then press the On-Off button until the TV responds (up to 300 times). Then press Enter to store the code.
However universal remotes codes are limited to those for devices released at least 6 months before the remote was programmed. If your TV is newer, you may need a newer universal remote.
The manual is available here: http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/24914-Manual-Eng-Spa.pdf . The code lists are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
I hope this helps.
Jan 16, 2011 | GE Televison & Video
Codes search for a radioshack 15-2147 remote
Here are the codes...1447,0047,0051,0178,1347,1917,1147,1907,1922,1919,.....To program.. Turn the TV on, make sure you have fresh batteries in the remote,and installed correct, Press and hold down the P button until the LED blinks twice, enter one of the four digit codes, the LED will blink twice,it not, repeat the steps using a different code..hope this was helpful...
May 30, 2010 | Radio Shack 15-2147 Remote Control
I need a code for my living solutions universal big remote for my GE projector screen 48in tv and instructions on activating it
The codes for your Living Solutions Universal Remote to control a GE television are 000, 003, 004, 009, 015, 022, 031, 044, 052, 054, 055, 087, 092, 103, 107, 125, and 164.
To program your remote follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Jul 18, 2009 | Innovage Jumbo Remote Control
Iview 352PTV TV Logo
529 people viewed this question
Top Iview Televison & Video Experts
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you an Iview Televison and Video Expert? Answer questions, earn points and help others
