Question about AOpen MK79G-N (91.8B110.101) Motherboard
RAM compatibility with MK79G motherboard
I have bought 1Gb of RAM (DDR 333 PC2700 184 pin) for my MK79G motherboard but it does not seem to be recognised by the motherboard. I have tried taking out the 256Mb memory currently installed and slotting hte new memory in the first memory slot but the machine gives out an intermittent beep when switching on and will not boot. Putting both the 245Mb and the 1Gb memory in together allows the machine to work but only recognising 256Mb.
From my limited technical knowledge I think I have got the correct RAM but I am unclear why it is not recognised by the motherboard - are you able to advise me please?
  • keefmorgan Feb 16, 2009
    Thanks for your response.
    THe original memory was 256mb ddr pc2700 / 333mhz. THe new piece of memory I got was also 333 mhz. I tried using just the new module I bought without the original memory (tried in both slots) but the machine didn't boot at all. I can only presume I have got the wrong memory module or one that is not compatible with the MK79G motherboard?
    I found the following description on the Fixya website which has an on-line manual:
    With NVIDIA nForce2-G/GT chipsets, the MK79G-N / MK79G-1394 can support Double-Data-Rate (DDR) RAM. The DDR RAM interface allows zero wait state bursting between the SDRAM and the data buffers at 400/333/266/200 MHz. The four banks of DDR RAM can be composed of an arbitrary mixture of 64, 128, 256, 512MB or 1GB DDR RAM and maximum up to 2GB. The MK79G-N / MK79G-1394 allows DDR RAM to run at either synchronous or pseudo-synchronous mode with the host CPU bus frequency (400/333/266/200MHz) (When enabling VGA onboard, memory can run max. up to 333MHz).
    This seems to suggest that memory with different sizes can be mixed but it also mentions 'four banks' and i'm pretty sure there are only 2.
    THe rest of it doesn't make a lot of sense to me.
    Does the make of the memory affect its compatibility? Is it possible I have bought the right specification of memory but that it just isn't compatible?
    I suppose the other option is that the memory is malfunctioning but that should be fairly unlikely I would have thought (having been careful to handle the module correctly and earth myself before handling etc.
    Scholar:
  • 172 Answers
Hi, I am assuming that the original piece of memory was a 256mb ddr pc2700/333mhz ?
i have looked at your board on the product maker website and it supports memory to 2gb of pc2100,pc2700/pc3200 type memory. Be certain however that the new piece added is the same clock speed as the original that you are trying to use with it. You cannot mix clock speeds, either pc will not boot or it will only recognise the compatible piece. Have you tried booting with just the new piece 9 leaving out the older piece)if yes what was the result. Need more help ?? compdoctor2005@btinternet.com
Posted on Jan 03, 2009
What kid of memoria i can to add to my pc? and how much i can to add?
This is a rather old motherboard so it will not support much RAM. It is my assumption that it could not handle more than 1GB.
The motherboard takes DDR 333 184-pin RAM. You can find a selection of RAM of that type at this link: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007611%20600006040%20600006083&IsNodeId=1&name=DDR%20333%20%28PC%202700%29
Apr 12, 2011 | Intel D845GVSR Motherboard
Can i upgrade my intel D845pesv mother board with 1GBDDR3 RAM ?
No, that motherboard only has two DIMM sockets that support 184-pin connections, DDR3 RAM only comes in 240-pincount. Your motherboard does support up to two gigabytes of RAM, so you could buy two 1GB sticks of DDR 184(pin) SDRAM DIMMs at 333/266Mhz (the speed of the ram)and install that.
Dec 22, 2010 | Intel D845PESV Motherboard
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
Cant install new 1gb pc3200 memory into my chaintech apogee 9pjl motherboard. as soon as power is turned on, i either get a constant beep or a neverending intermitant one. please help.
Some memory brands are not compatible with some motherboards. Go to the motherboard web page and check it for the kind and brand of memory you can use.
Oct 03, 2009 | Computers & Internet
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
AOpen MK79G-N (91.8B110.101) Motherboard Logo
89 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
