Question about Dynasty DGRSC 36-4G Gas Kitchen Range
Dynasty DGRSC oven gas not working
The gas does not even come on when the valve on the front of the oven is turned on. I think there is a safety feature that prevents the main gas flowing until the pilot flame is lit. But the light for the valve does not come on so I think it is an electrical problem
  • 93 Answers
SOURCE: What is the part number for a Dynasty DGRSC oven
Dynasty ph # 800-884-5233
Posted on Mar 02, 2010
  • 93 Answers
SOURCE: Dynasty oven fails to get enough gas to light.
I think you are talking about the oven safety valve or thermal valve. before you change you oven safety valve, I would check the Amperage on the oven ignitor first, install AMP meter on one of the ignitor wire, it should draw above 3AMPs, if not then you have problem with the oven ignitor and not the safety valve. we hardly change the safety valve, I'll try to change the ignitor first. Have fun.
  • 93 Answers
SOURCE: Replace Dynasty Range oven light lens?
Call Dynasty / Jade ph # 800-884-5233
marka19
  • 1430 Answers
SOURCE: The Oven Won't Light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 08, 2010
SOURCE: I have a dynasty DGRSC-30-4
Are you using natural gas or LP??
Posted on Dec 12, 2010
May 08, 2010 | Dynasty DGRSC 30 Gas Kitchen Range
LOOKS LIKE NO GAS TO OVEN. GLOW STICK LIGHTS IS YELLOW-BROILER LIGHTS...GLOW STICK SAME COLOR AS OVEN'S
You need a new thermostat for the oven. It isn't picking up the heat from the ignitor. They're relatively cheap and easy to replace.
Sep 06, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Mar 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Need instruction book
Jade / Dynasty ph# 800-884-5233, most cases the big BANG noise is coming from the broken oven bottom pan, small BANG is normal, if you know how to remove the bottom them pull it out and inspect it, part of the V shape flame spreader may come off from bottom pan, you can have the welder weld it back on for you or order new bottom pan thru Dynasty. I'm not sure what do you mean by gas shut off. (turn off oven? turn off burners?)
Mar 22, 2009 | Dynasty DGRSC 36-4G Gas Kitchen Range
Oven has stopped working
Bad oven ignitor, to check it, turn on the oven, check Voltage on 2 ignitor wires, it should have approx. 110v, if yes, change the oven ignitor, if not then check oven safety valve of oven thermostat, but 90% is the oven thermostat. also make sure the oven tube is not corroded at the ignitor area, if so, change the oven at the same time. Have fun.
Jan 20, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Oven failing to light
The ignitor needs at least 3.2 amps current flow to heat the bi metal in the gas  control valve enough to allow the gas to flow. cold ignitor (red) will not flow enough current, when ignightor gets yellow resistance drops enogh to allow bi metal to heat and allow gas valve to flow and ignight gas. most likely your ignitor is shot
Dec 20, 2006 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty DGRSC 36-4G Gas Kitchen Range Logo
21 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
