Question about Keurig B60 Coffee Maker
My keurig will not fill with water - Keurig B60 Coffee Maker
  • 1,511 Answers
Uppewr line is plugged and/or filter needs replacing.
Posted on Feb 06, 2014
How do we descale our Keurig coffee maker
Fill the water tank with vinegar and then brew a cup a coffee using nothing but putting lever in brew mode.
Repeat several times, then fill water tank with clear clean water and repeat brewing process until no vinegar taste remains.
I have used my Keurig for years and never had to de scale.
Are you sure it needs it.
If this is a continuing problem suggest a portable reverse osmosis unit and use water from it Vs your tap water.
They can be had on ebay for under $100 and are easy to install. Coffee tastes better too.
May 25, 2017 | Keurig Coffee Makers & Espresso Machines
De-scaled by using vinegar as suggested now every cup tastes like vinegar
Keep filling your water reservoir with water and running it through, until it clears up, it might take a few fill ups of your water reservoir to get the vinegar taste out.
Oct 08, 2016 | Keurig B70 Platinum Brewing System B-70
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
Cannot prime
I have the same unit. You need to descale it. Get a bottle of white vinegar (not the small bottle, the next size up). Unplug your Keurig. Empty out the water receptacle and flip your unit over in the sink to remove any residual water in your unit (I even shake mine a little to loosen up whatever is stopping it from priming. Fill the water receptacle to the top with white vinegar. Plug in the Keurig and turn it on. Cycle the unit (lift the lever, close it, push the button) and fill a cup with heated vinegar. Pour the cup out and continue until all the vinegar is gone, then fill the receptacle and keep doing this (I do it until the receptacle has emptied itself at least 3 times). If your Keurig will not allow you to cycle through this then the problem is internal with the pump. Call Keurig. If you are in your warranty period they will replace.
Dec 10, 2013 | Keurig B60 Coffee Maker
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Our Keurig is in Australia using a transformer for voltage. Brand new and keeps telling us to prime ????
Hi. Open the steam/hot water outlet while it is heating. This allows the air to come out, and water to fill the water circuit. The pump will be noisy at first, but will quiten when water has filled it. Good luck and enjoy your coffee. Dazza. Repairer 0401 200 901. Queensland
Oct 22, 2011 | Keurig Platinum B70 Coffee Maker
After filling the water holder, it will not prime, the light keeps flashing that there is no water.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 09, 2011 | Keurig Platinum B70 Coffee Maker
Prime appears in the window of my Keurig. How do I get air out of the line
heatman101
Sep 06, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Keurig B60 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
