Question about Motorcraft 1999-2003 Ford Windstar Window Regulator, 00-02 WLRA-39
Instrument cluster lights
Lights will not turn off
    Master:
  • 444 Answers
The multi function switch has to be replaced,
Posted on Oct 29, 2012
All my gauges just quit working. car still runs fine. they done this 2 or 3 times but would always start again. this time have not come back on. turn signals and dash lights work just no gauges.
At the moment, your instrument cluster maybe faulty? Due the basic tests, try to be sure. Check for applicable trouble codes relating to instrument cluster--pcm--communication codes. Some of the national brand auto stores in this country may check codes for free, if there are any.
Check voltage and ground circuits for the instrument cluster. The sending units for gages are wired to pcm then the pcm sends serial data to instrument cluster telling instrument cluster what to do with gages. If you want to check gage sending units, that's ok.
If you have a scanner that can communicate with instrument cluster, you can get instrument cluster to do a self-test. The self-test, the instrument cluster will turn warning lamps on and off, sweep gages w/o outside data input. The instrument is considered good, if it passes that test, if not, the instrument cluster is considered faulty.
Apr 28, 2016 | 2002 Pontiac Bonneville
I just bought a 1998 Pontiac Bonneville and now the system monitor light is on why and what does that mean?
No other messages in the driver info center ?
This section provides an overview of the instrument cluster operation as well as a detailed diagnosis. The instrument cluster serves as the primary interface for the vehicle's driver.
The instrument cluster contains a microprocessor as part of the instrument panel assembly. The instrument cluster performs the following functions:
• Recognizes operational malfunctions
• Alerts the driver through indicators
• Stores DTCs which identify malfunction areas
In order to perform all of these functions, the instrument cluster microprocessor has its own inputs, outputs and program software. The instrument cluster has the capability to diagnose malfunctions in the following components:
• The sensors
• The input switches
• The components
• The systems the instrument cluster communicates with or controls
When the instrument cluster or another microprocessor-controlled module detects a malfunction, the instrument cluster may turn on an instrument cluster indicator in order to alert the driver that a malfunction has occurred. Some indicator lamps have dual controls. Your best bet is have it checked for DTC'S diagnostic trouble codes !
Mar 02, 2016 | Pontiac Cars & Trucks
Instrument cluster gauges
Check engine light ,abs , air bag lights etc.... come on when key turned on ?
Fuse IPC/HVAC BATT 10 amp located in the left IP junction block . Do you know where this junction box is ?
Does the heater an A/C work ? If so the fuse isn't the problem .
Speedometer
The speedometer is a road indicator. The vehicle speed sensor (VSS) is a permanent magnet generator which is located on the transaxle. The VSS sends an input to the PCM whenever the transaxle differential carrier turns. The PCM then buffers the VSS signal. The PCM transmits the VSS signal to the following components at 4000 pulses/mile through CKT 817:
• The instrument cluster
• The cruise control module
• The radio (uplevel)
The instrument cluster uses the input in order to indicate the vehicle speed on the speedometer.
Instrument Cluster Indicators
The BCM controls the instrument cluster indicators through the SPI serial data communication bus. Refer to Body Control Module System Check in Body Control System.
IPC/BFC ACC
10A
Instrument Cluster and Body Control Module (BCM)
IPC/HVAC BATT
10A
Instrument Cluster and Heater A/C Control Assembly
Jul 24, 2017 | 1998 Oldsmobile Cutlass
2005 Civic Temp Control & center dash lights not working -blower & all vent settings are functional ,I have checked all fuses under column & underhood with NO blown fuses
Your instrument cluster and console lights are protected by fuse #2 (15 Amp) in the underhood fuse and relay box. They actually get power from the tail lamp relay. If the tail lamps are working, the relay and the fuse is not your problem. The brightness of these lights are controlled by the Multiplex Control Unit and theCPU built into the instrument gauge cluster. The dimmer circuits are actually integral with the instrument cluster. If the tail lights are working and the lighting in the instrument cluster is working, then the problem is either a CPU failure in the instrument cluster or an open circuit between the instrument cluster and the center console lights. The console lights themselves should have power all the time that the tail lights are turned on. The CPU in the instrument cluster provides ground for them to function. The wiring is a little different depending on which model you have and how it is equipped (LX, DX, EX, LX with side curtain airbags, etc.) however, the function is the same.
I highly recommend scanning your computer network for fault codes before spending a lot of time trying to perform electrical diagnosis. There may be a fault code present that will lead directly to the cause.
Sep 15, 2011 | 2005 Honda Civic
Changing dashboard light
This solution will be of great help to you,even in the case of future or other dashboard problems;
Instrument cluster consists of electronic analog gauges, various warning lights, and optional tachometer. Vehicles equipped with tachometer have an electronic vacuum fluorescent transmission range indicator (PRND3L),odometer and trip odometer display. Vehicles without tachometer are equipped with a cable-operated transmission range indicator.
Instrument cluster is equipped with the following warning lights:
Battery voltage.
Cruise (speed control).
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Low windshield and washer level.
Traction Control.
The Body Control Module (BCM), which receives input from various sensors, sends display information to instrument cluster and operates gauges. Instrument cluster incorporates a self-test diagnostic feature to identify electronic problems. BCM, Powertrain Control Module (PCM), and Transmission Control Module (TCM) are continuously monitored by the diagnostic system.
SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON position. Continue to hold TRIP and RESET buttons until odometer window displays CODE (approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
CodeDescription
110.......Cluster Memory Fault
111.......Cluster Calibration Fault
905.......No CCD Bus Message From TCM
921.......Odometer Fault From BCM
940.......No CCD Bus Message From PCM
After diagnostic code display ends, instrument cluster will go into each of the following tests in order:
Dim test.
Calibration test.
Odometer segment test.
Electronic Transmission Range indicator segment test.
Dim Test
CHEC-0 will be displayed in odometer window. Instrument cluster will dim Vacuum Florescent (VF) display. If VF displays do not dim, a problem in instrument cluster exists. See BODY CONTROL COMPUTER TESTS in BODY CONTROL COMPUTER article.
Calibration Test
CHEC-1 will be displayed in odometer window. Each of instrument cluster gauges will move sequentially through each calibration point. See GAUGE CALIBRATIONS table. If gauge needle is not calibrated properly, a problem in instrument cluster exists.
Odometer Segment Test
CHEC-2 will be displayed in odometer window. Each segment of odometer will light sequentially. If any segment does not light, replace instrument cluster.
Electronic Transmission Range Indicator Segment Test
CHEC-3 will be displayed in odometer window. Each segment of electronic transmission range indicator will light sequentially. If any segment does not light, replace instrument cluster.
Aug 09, 2010 | 1998 Plymouth Voyager
Instrument cluster bulb is out. how do i replace
It may not be a bulb, as the instrument cluster usually has a number of bulbs and they probably didn't all blow at once. Pulling instrument clusters can be touchy and may not be for the average "shadetree mechanic" however, typically there are a few screws above the cluster going into the dash pad and a few hidden behind the trim panels below the cluster.
Dec 22, 2009 | 2001 Chrysler Sebring
Check engine light does not turn on at all
The bulb is probably loose and/or burnt out. If you are mechanically inclined you can tackle this job... This procedure is the one i use, most often it's the blue high beam indicator bulb that goes so if you want to change it while your in there.....(hint hint)
Disconnect and isolate the battery negative cable. Wait a good 2 minutes to allow for air bag deactivation...NOTE: USE CAUTION ...Lower the tilt wheel to lowest position.
Remove the cluster bezel from the instrument panel.
Remove the two screws that secure the upper mounting tabs of the instrument cluster to the underside of the instrument cluster hood formation of the instrument panel top pad.
Remove the two screws that secure the lower mounting tabs of the instrument cluster to the instrument panel structural duct.
Pull the upper mounting tabs of the instrument cluster downward, then pull the instrument cluster rearward far enough to access the instrument panel wire harness connector for the instrument cluster. Disconnect the instrument panel wire harness connector for the instrument cluster from the connector receptacle on the back of the instrument cluster housing.
Remove the instrument cluster from the instrument panel. Now do you remember which bulb it was? You can now see where the check engine light bulb is mounted. Twist and remove, install in reverse order. In some cases they are just loose or not making good ground, but after going through this just to access that lil bugger, i'd replace it.
I hope i have helped you and if you feel i have please acknowledge.
Be well and keep the cherokees alive....
May 13, 2009 | 2001 Jeep Cherokee
Instrument lights won't turn off
hi,seem lighting switch is grounded or wiring for cluster is grounded,if can remove the lighting switch disconnected the wire,see if light in cluster is off,switch or wiring must check,ty
Mar 29, 2009 | 1991 Jaguar XJ6
Gas gauge no longer works
The light behind myRemove the cluster bezel from the instrument panel. See Cluster Bezel in this group for the procedures.
Remove the four screws that secure the instrument cluster to the instrument panel Instrument Cluster Remove/Install
Pull the instrument cluster rearward to disengage the two self-docking wire harness connectors
NOTE: The instrument cluster has two self-docking wire harness connectors that will be automatically aligned with, and connected to the instrument panel wire harness when the cluster is installed in the instrument panel.
Remove the instrument cluster from the vehicle.
Reverse the removal procedures to install. Tighten the mounting screws to 2.2 N·m (20 in. lbs.)
when I turn my headlights on. All the other gauges are lit, but not the gas gauge. How do I get in there to replace the bulb and fix this? Or is it a fuse problem? I have a 1998 jeep scout Thanks
May 14, 2008 | 2007 Jeep Scout
Motorcraft 1999-2003 Ford Windstar Window Regulator, 00-02 WLRA-39 Logo
64 people viewed this question
Top Motorcraft Scuba Diving & Snorkeling Experts
Jesse Garza
jeff5may32
bobalix
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
