Question about DeLonghi ESAM5500
My Delonghi ESAM5500 has had pre ground coffee inserted into the beans container. Now coffee will not come out, I called Delonghi and they said to vacuum it out, and that I must release the grinder an
Pre ground coffee in beans container? How do I release and reset the grinder?
5 Suggested Answers
debrewerz001
  • 17 Answers
SOURCE: delonghi coffee machine service providers in india
please contact Mr. Prashant Suthar, India, www.debrewerz.com
Posted on Sep 20, 2010
SOURCE: my delonghi esam5500 coffee bean grinder part is
In our case we were lucky. Grinder was blocked by the beans. This is what I have done with our Delonghi 5400. It looked fiddly but was quite simple really. I started from the back panel. Once back panel was removed I had access to 4 corner screws that remove both side panels. Now that give me access to 4 corner screws that hold top of the machine. I l also had to unscrew 5 screws that hold coffee container in place. 4 are visible once the coffee beans container is open, but the 5th is hidden in the middle of adjustment arm with a black cap on top.(adjusting how fine you grind). I used small sharp screwdriver to lift the cap. Once all are out I removed the top of the machine and then the funnely coffee container too. That exposed grinder assembly. Top of the grinder is actually loosely sitting in the lower part of grinder. Twisting it counter clock should release it I Think. Our was not budging, and I had to completely remove the grinder and detach motor but that is quite obvious too, and probably not needed. I just wasn't sure what I was doing. Our machine was out of warranty so... Would be nice if we had some schematics.
Posted on Feb 26, 2011
espressonist
  • 1711 Answers
SOURCE: ECAM 23.450: I was accidently
From what we can understand the gound coffee have move in the grinder plates. If this is the case you need to udjust the grinder to more gross coffee. try to vacuum again so you get out some more grounded coffee. Then use some beensand try to make some coffees. The coffee will run fast but this will help to remove all the grounded remains from grinder. After a few coffees you should turn the grinder udjustment back to it original place. Take care tha you turn only one to two step at a time perform a coffee and then you can turn again the grinder to more fine.
You can also remove the whole brew group and wash it well so everything will be as before.
Posted on Jul 26, 2011
espressonist
  • 1711 Answers
We beleive that this is the same question as the previus we jus ansewr
I am house sitting and do not know where Delonghi Perfecta Cap. machine's grounds container is located? indicator says to empty now...
Hello, Jean -
Delonghi makes a number of different cappuccino machines. If you had stated the model number of the machine, I probably could have found you the manual for the homeowner's machine online.
I found a user's manual for the Delonghi ESAM5500. The manual has an illustration which shows where the grounds container for that machine is located. If the homeowner's cappuccino machine is not an ESAM5500, the grounds container for their machine may be in a similar location.
This is the link to the user manual for the Delonghi ESAM5500:
http://kavegepbolt.hu/shop_ordered/9160/pic/Saeco/DELONGHIESAM5500.pdf
It is a PDF document, so you will need Adobe Reader software (free).
Page 17 of the manual talks about how to clean the machine, including cleaning the grounds container. In the instructions part A9 (which is illustrated on Page 3 of the manual) is identified as the grounds container.
Just to be sure, if you can contact the homeowners, do so and ask them where the manual for their cappuccino machine manual is located, so you can refer to it and so that you do not accidentally damage the machine.
Best wishes.
Feb 09, 2018 | DeLonghi Coffee Makers & Espresso Machines
MESSAGE GROUNDS TO FINE
If the grounds are too fine the water will pool and not wash through the grinds which could lead to an over flow. Proper size grind is important. Use an alternative source fro grinding the coffee.
Feb 02, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Pre ground coffee
SORRY but FIXYA does not make coffee nor do we repair coffee makers . contact the manufacturer thru their website and ask tech support to assist
Oct 13, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
DELONGHI PERFECTA SAYS INSERT GROUNDS CONTAINER WHEN IT'S ALREADY INSERTED
Just had the same problem after washing my ESAM5500.
Seems that some water hot on the switch that is triggered when grounds container is inserted.
My solution was removing the bottom panel (5 screws if I remember correctly) and disconnect the green wire from the switch (there are three wires - green, ping and blue). When the green wire is disconnected, coffee maker thinks that grouns container is inserted all the time - even if it is removed.
Jul 30, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Keeps saying fill beans container when already full
The machine understant that there is not any beans in the container by the mesuring how easily the grinder motor rotates. If there is not any beans in the grinder motor rotates freely. In your case means that the beans from container are blocked to enter down to the grinders disk plates or they partialt enter, so the motor runs more freely and machine understant that there ae not enough beens. So you need to remove the beans and container and by the use of a vaccum cleaner remove all remainings from the grinders entrance and funel. You can also use a brush to remove any coffe oils and remianing so the bean can easily slide inside the grinder.
Jun 25, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Locating manual as coffee machine is unable to select appropriate grounding for coffee
There seem to be a number of different sub-models of the ESAM5500 line of superautomatic coffee makers.
You can see a list of all of the user manuals for these sub-models here:
http://web1.dlservice.org/dlservice/ext/delonghi/cercalibretti.php?cerca=ESAM5500&submit=Search
Good Luck!
Dec 28, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My delonghi esam5500 coffee bean grinder part is not working. seems to be blocked, can see beans moving when it goes to grind but no beans are taken in and it comes up with fill beans compartment? what...
Nov 26, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
DeLonghi ESAM5500 Logo
76 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
