Question about Cub Cadet Garden
Blew a fuse on my cub cadet zero turn riding mower replaced fuse now pto will not engade the mower blades but will die if you get out of seat
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Must be another fuse somewhere
Posted on Nov 22, 2013
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
pippall
  • 1486 Answers
SOURCE: my rzt 50 series cub cadet zero turn mower slows
The saftey wires wont cause it to slow down.Thats more of a fuel problem.Check the carb remove and clean the float chamber.Also check advance and ****** springs are still in good working order on carb.
Posted on Jul 06, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 13 Answers
SOURCE: Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
Posted on Aug 15, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Ihavert42.zero turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Zero force 50 Cub Cadet runs fine , but when the mower deck switch is pulled , blades do not turn, does not engage
This would be one of a few different things, first check to make sure the belt is on properly and hasnt came off any pulleys, next check the clutch relay and fuse, next check the pto switch, and if all those check out, check the clutch for engagement, if it tries to engage with pto switch, then it may just need adjusted, if it doesn't try to engage, the clutch will need replaced, but check the other possible causes first.
Oct 14, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I have a 20 hp z force 44 and the mower blades wont come on . I have changed the pto switch and the safety switch under the seat. I have also checked the fuse and its good. what else is there?
Hi, check you have voltage at the pto plug in connector when the mower is running and the pto switch on. If so the pto needs replacing. If not you have a bad contact or broken wire somewhere. Hope this helps, regards Phil.
Jul 22, 2011 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Aug 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
100 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
