Question about Sony STRDH520
I just hooked up my Sony STR-DH520 to my Sharp Aquos TV. How do I get the Sony remote to operate my TV?
SOURCE: Remote control unit
Follow the instructions on this website below, and make sure that you select AV1
http://www.remotecentral.com/cgi-bin/mboard/rc-sony/thread.cgi?4020
Regards,
Kevin
Posted on Dec 31, 2008
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
SOURCE: Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Posted on Apr 15, 2009
dunnbiker
  • 8546 Answers
SOURCE: HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Posted on Mar 21, 2010
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
STR-DH520 Sony av receiver , Protect sign keeps coming on and I have no wires connected at all! How can I fix ??
There is most likely a short in the amp that needs to be repaired. Probably a pair of shroted output transistors as well as a few resistors will need to be replaced.
Dec 17, 2014 | Sony STR-DH520 A/V Receiver
Dh520 protect mode
Usually means you have a blown amp channel. Shorted output transistors and burnt resistors.
Oct 06, 2014 | Sony STR-DH520 A/V Receiver
How to get sony air-sa10 to pair with str-dh520
Interesting problem. Note that this wireless system is proprietary - meaning that only Sony provides a solution for you.
From what I have been able to research (remember, Google is your friend), you will need an adapter for your receiver to generate the proper wireless signals. See the links below: Sony EZWT100 AIR Signal Transmitter Black Old Version Looking for Answers about Sony ALTUS AIR Transmitter for AIR Compatible...
Apr 27, 2014 | Sony Air-sa10 Wireless Speaker System...
Uverse remote s-10-s1 codes for sony str-dh520
For Sony STR-DH520 the AT&T Uverse code is 5151.
Jun 07, 2012 | Sony Audio Players & Recorders
Can't turn off the closed captioning
I had the same problem. Okay, First get the TV remote. not a cable box remote. Next, switch the input to an Analog input. (TV or input one if you have the RC red, white and yellow hook up. or, just hook up the coax cable straight to the TV..
Now, use the TV remote to operate the closed caption. It will work like it should.\
Briefly, closed caption works on the TV with a straight hook up to the TV. It will not work with a cable box.
Good LUCk
Monty
Aug 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to Operate a sharp TV without a remote control
HOW DO I GET A REPLACEMENT REMOTE CONTROL FOR SHARP AQUOS LC37GA4X
Dec 10, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Tv codes
YES throw that old sony remote away .
Jul 15, 2017 | Sharp Aquos LC-32D40U Television
Sony STRDH520 Logo
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
