Question about Sansui HDLCD1912 19in LCD HDTV 720p
My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Dell Dimension B110 desktop. The monitor works fine through the Dell and Windows XP start up screens, but after the XP screen, it just does a black screen. I can hear the computer loading, but nothing's popping up on the screen.
  • 210 Answers
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
Posted on Oct 29, 2012
SOURCE: Sansui HDLCD3200b Drivers for PC
The TV has a resolution of 1366 x 768 for mine, I set the display properties to1280x768 the closest you can get to the actual 720p resolution.
Posted on Jan 23, 2009
SOURCE: I have a Sansui HDLCDVD260,
I have a same Sansui HDLCD 2600 which did not have anything happen when try to switch on. no lights even on the power led. where can I get the replacement parts?
Posted on Jun 28, 2009
  • 159 Answers
SOURCE: i hv sansui flatron tv
If possible eaily take it straight back to the shop it came from or whatever advice the instruction book tells you depending on where in the world you are.
Posted on Sep 20, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Computer vga cable/ sansui tv problem
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Posted on Nov 02, 2011
christop_nor
  • 37 Answers
SOURCE: how do i get my sansui tv to work as a computer monitor
dose your tv have capability for use as a moniter, if so all you need is a cable from your computor to the back of your tv, you will need to make simple ajustmenys to your tv.
Posted on Feb 12, 2012
Monitor goes from on to standby while computer boots up. Changed cord and cord but does same thing as soon as I plug it in. Any help
Plug monitor into another known working computer. If it does not work then the monitor has died a noble death. If it works in other unit then the video card of the Dell needs to be replaced.
Mar 12, 2014 | Dell Dimension B110 PC Desktop
Monitor
the original working frequency for that monitor is either to high or too low for the grapchics card inside your computer! Try the monitor on other computer and try to reduce or increase the working frequency! Or maybe is just you need a driver for that monitor to work on your pc!
Oct 18, 2012 | Dell Dimension XPS PC Desktop
Dell B110 turns on but no signal to monitor. Help.
If you have a short display of the devices and the blue screen flashes when you get to windows and shuts down ..than it is a hard disk issue ..God to bios and disable the ahci function for the hard disk bus..and let it run on ide compatible or sata as ide..This is happening when you have a hard disk on sata with ahci on ..and you do not have drivers in the system ..
But if there is no start at all ..it is a different cause and probably the video card damaged if it says no signal ..
Anyway check them all one by one ..cpu fan ..hard disk in and out ..(see if you can boot to bios ) ..and ram memory ..remove tehm and place back ..one by one to spot a potential harmed one ..
Dec 31, 2011 | Dell Dimension B110 PC Desktop
My computer won't read the new camera I've got. Even after installing all info from cd. Have tried camera and it works on tv. It won't let recognise the device on problem either. What can I do?
A camera that works connected to a TV without software is not the proper device to connect to a computer. Check again with your packaging and instructions.
Having a camera working on the computer and then porting the video signal to a TV monitor is the preferred arrangement.
Install the software, reboot, then connect a PC camera, it should be recognized and be testable on Skype, etc.
Sep 12, 2011 | Dell Dimension 3100 PC Desktop
Blank screen when powering up
Hi
Check the power cable connected to the monitor.
If you have another monitor connect the same power cable to the monitor and see whether the monitor screen comes up or not.
if not then no problem with monitor may be OS is faulty
else your monitor is having the problem
Jan 22, 2011 | Dell Dimension™ B110 PC Desktop
Inspiron b110 wont turn on only green flashig
Unplug your computer, wait 30 minutes, plug it back in and try again.
If it still doesn't work, it's got a serious problem. If it isn't under warranty with DELL any longer, take it to a reputable repair facility.
Apr 14, 2010 | Dell Dimension™ B110 PC Desktop
Dell dimensio B110 computer does not start beyond the startup window
while the pc is booting up hit F8, it should take you to a sub menu, choose "last known good configuration" and hit enter, see what it does.
post back please
regards
Nov 27, 2008 | Dell Dimension B110 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Mainboard not reconizing my hdd
check to see if your ram has not losse, had the same problem with a mates computer.
Jul 03, 2008 | Dell Dimension B110 PC Desktop
Sansui HDLCD1912 19in LCD HDTV 720p Logo
213 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
