Question about Schumacher PI-400 Instant Power DC to AC Power Inverter - 400 Watts
Schumacher power inverter pi-400 problems
Connected inverter to car battery and ran plug to a 115v sump pump. Pump recieved one second surge then PI-400 clicked off. What am I doing wrong?
4 Suggested Answers
Skinnerd1
  • 13 Answers
SOURCE: Need manuel
Here is a link to your manual.
http://manuals.batterychargers.com/manuals/00-99-000854.pdf
Posted on May 22, 2009
  • 608 Answers
SOURCE: Lost the wall charger of my Schumacher 400w power
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire.
I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
Posted on Mar 21, 2010
SOURCE: I need a replacement charger for my Schumacher
will not charger the batterys
Posted on Apr 24, 2011
Pump continuosly runs after water is cleared out of basin
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Mar 24, 2014 | Hydromatic Pump Hydromatic V-A1...
Have a PI-1500 Schumacher that I just got and trying to hook up to a litium Ion battery with charged voltage of 15.86 - lights on inverter light up(red and green) but no power output--- Is this battery...
you must be careful you can not interchange Lion and Nicad there voltages are not compatible and the intelliichargers will register a fault you must replace with same batterys recomended for your unit
Oct 24, 2013 | Schumacher PSI-1500 1500W Pwr Inverter
Pi-400w power inverter manual of service
Double check whistler's website for a manual ( PI 400 Power Inverter ) or call 800-531-0004
Sep 21, 2013 | WHISTLER PI-400W 400-Watt Power Inverter
What's your problem?how many amps on a 1/2 horse sump pump
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Apr 28, 2012 | Black & Decker Husky 750w Power Inverter
How long can I use my adapter to run my sum pump before draining my vehicle's battery
Be sure that the inverter can handle the load of the sump pump.
The vehicle should be running while the inverter is in use unless the sump pump only runs maybe once every other hour or so. Make sure you don't run the vehicle inside an enclosed area like a garage even if the door is up. Exhaust fumes may still get into the house. This inverter size is barely large enough to handle a standard sump pump.
Aug 27, 2011 | Powerline 0900-73 Slimline Inverter
I have a coleman powermate pmp400-t inverter 400w/800w will it power a sump pump? I tried it and it beeped and the fault light came on
Hello, the answer is no. This inverter will work with a pump that below or about 400 watts power for operation. I notice it says that the inverter 400w/800w. The 800 watts is the surge required to get an electric motor to run. On a single phase motor (120 AC) and it take 4 amperes to operator this motor. But to start the it will 12 amperes to start it. This is one reason why on a lot of electrical motors there will be a big tube or can, this is the starting capacitor, it stores energy in form of current (amperes) to drop across the windings of the motor when it starts. If some electric motors didn't have this capacitor. The most likely scenario would be tripping a breaker because it drawing to much current.
Now, for you problem. Example of Power and the unit of the formula is V (volt), R (resistance) I (current) P (power) Ohm's states that :
Now Power would be stated: P = V times(x) I. Therefore in your case, if the pump at normal operation is drawing 4 amps of current for operation pumping water. The power factor would be 120 V AC (house voltage) times (X) I (current) which 4 amps. So here is what you have: P = 120 X 4 equal= 480 watts.
Therefore, your inverter will not work because it operating at 80 watts more than the power inverter can deliver which is 400 Watts.
If you need to purchase a new power inverter, remember always take into account the Amperes required for operation. Just by the simple Ohm's Formula. Best of Luck. GB....stewbison
son
Aug 27, 2011 | Coleman Electronics - Others
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
Schumacher PI-400 Instant Power DC to AC Power Inverter - 400 Watts Logo
47 people viewed this question
Top Schumacher Electronics - Others Experts
eyecam
ray012965
indiana650
indiana650
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
