Question about Rancilio Silvia Espresso Machine
Rancilio steam wand loose not working
The rig wand on our commercial rancilio does not work suddenly. The knob continues spinning to no effect. The wand is now cold though the attachment piece inside the machine is still hot. Is there an easy fix? What are potential problems?
    New Friend:
  • 3 Answers
Rig wand! you mean steam wand?
Take lid off and see if the knob clib connection to the steam valve is come out. Otherwise, possibly the steam valve's portioning washer is hardened and stuck. BUt sound slike shaft is broken or lost connection to the valve
Posted on Nov 24, 2012
  • Hazel Quilter
    Hazel Quilter Feb 13, 2015
    how do you put the knob clip back on i have been trying for 2 days very frustrating when you need a coffee haha
SOURCE:
SOURCE: Steam knob is stuck in "open" position
I have the same problem. I also can't turn the shaft with pliers. If anybody has any advice I'd appreciate it.
Dan
Posted on Feb 18, 2008
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
z34aga
  • 137 Answers
SOURCE: leaking steam valve rancilio miss audrey
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Posted on Apr 02, 2009
  • 80 Answers
SOURCE: The machine is only a couple months old. It is
check grinder maybe is too fine ,go litlle bit courser and try
Posted on Aug 22, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
Posted on May 30, 2010
Testimonial: "Had the problem fixed in 5 minutes. Saved me a lot of inconvenience and (probably) money. Thanks for the solution."
I have a rancilio epoca 1group. After I turn the steam wand off it keeps steaming. Would it need a new valve?
Hi Daren,
You could replace the whole steam valve wand but you don't need to.
The rubber grommet inside the steam valve is worn out and the tap wont close properly - that is why the steam is coming out.
You will find these parts with a commercial rancilio supplier.
Feb 28, 2017 | Rancilio Coffee Makers & Espresso Machines
Rancilio Epoca S1 tank
Try editing brand and model number into your question.
Aug 03, 2015 | Coffee Makers & Espresso Machines
No water/steam coming out of wand
hi there,
do you hear the pump running when you ask for water or steam? You should hear the pump continuously when you ask for hot water, and intermittently when the steam is dispensed.
No hot water or no steam could come from many causes:
valve not working or not actuated (control board), and also the switch that closes when the water knob is turned may be defective.
Do you hear that switch clicking when you open the water knob?
Difficult to help further with so little behaviour information.
Good luck,
M.
Oct 28, 2017 | Saeco Vienna Plus Espresso Machine
Not getting a good/any froth. (Rancilio Silvia) My steam wand leaks air at the tip so I bought a new one and replaced that, it still leaks air. I don't want to tighten it too much so I won't crack it....
If steam wand leaks at the tip sounds like the steam valve needs to be rebuilt or replaced, because the valve seat is damaged or has mineral buildup keeping it open.
Apr 13, 2011 | Rancilio Silvia Espresso Machine
We've had the Rancilio Audrey now for a year and still not have had a perfect cappucino. 1. Milk. We use 3.5 dairy milk, cold before going under spout. 2. What is the middle (steam) button used for? ...
  1. That is the right milk. Use a thermometer with the milk.
  2. The middle button is used for steam. It engages the high themostat for steam.
    1. Slightly open the steam valve
    2. Turn on the middle button
    3. Keep the end of the steam wand slightly above the milk surface (0.5 mm) so the steam incorporates air into the milk. (Takes practice)
    4. Open the steam valve as the boiler heats up. (Takes practice)
    5. When the milk get to 74 C (165 F) immerse the steam wand into the milk and heat to 82 C (185 F)
    6. Turn off the middle button and shut the valve.
  3. For 90 ml of coffee, use 14 gram of ground coffee. The coffee scoop that came with the machine holds 7 grams of ground coffee as it comes out of a grinder (not packed). Tamp the coffee after it is in the sieve.
Jan 01, 2011 | Rancilio Audrey
How do I put the steam wand back in?...I removed it to clean and can't get it back in place?
Hi
There is a receptacle below the steam knob underneath. There are 2 o-rings in the receptacle or on the wand. Insert the wand into the receptacle, then screw the nut on until its tight. The wand should swivel.
Nov 23, 2009 | Rancilio Silvia Espresso Machine
Not heating up the water
Hi
3 things could be wrong. First is easy to check. With machine on, turn on the steam switch and after about a minut open the steam knob and push the middle switch. Check the water coming from the wand and see if its warm? If it is you need a brew thermostat. Unplug the machine. Remove the water tank. Remove the 4 screws that hold the top on and lift top off. The boiler has 2 thermostats on the top front of the boiler, and the one with the red dot is the brew thermostat and need replacing.
If that didn't fix your problem there is a reset thermostat on the front face of the boiler and has black wires going to it. There is a red button in the middle of the thermostat and needs to be pushed.
If that one didn't solve your problem you need a new heating element. You can do a continuity check on the terminals.
Apr 20, 2009 | Rancilio Silvia Espresso Machine
Water will not come through the steam wand
Dec 07, 2008 | Rancilio Silvia Espresso Machine
No water ever makes it through the pump
You have to prime the pump.. Hit the water button and open the steam knob.
If no water goes through the steam wand I would check for a clogged water line.
Ranclio parts and Espresso Machine information
www.CeriniCoffee.com
Nov 19, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
467 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
