Question about Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator
How mach cost gen power 305 10 hp ohv briggs & straton
What is the spark plug gap
Posted on Dec 05, 2012
4 Suggested Answers
Asbestos 56
  • 191 Answers
SOURCE: engine will not start. no spark. oil level is
There may be a engine control switch on it. It will be on the engine somewhere. it is differnt then a circuit breaker on the outlet panel. It also could be a bad ignition module.
Posted on Nov 18, 2010
mxc2
  • 146 Answers
SOURCE: no spark 10 hp briggs+straton
Remove the kill wire from the the back of the ignition module and test to see if you then have spark. If you have spark you would have a bad ground but if you still do not have spark then you may have a bad ignition module.
Posted on Oct 01, 2011
  • 18 Answers
SOURCE: I have a Gen Power 10hp OHV Briggs & Stratton
I recently had trouble with my own generator. My situation was that the old gas left in the unit smelled more like lacquer than gas, the generator had not been cranked in over a year, and it simply wouldn't even attempt to fire when pulling the starter cord.
I checked the oil level, and drained and replaced the gas. I applied liberal amounts of carburetor cleaner into carburetor. The generater would briefly fire with cleaner in the carburetor. I also removed the spark plug, grounded it against the chasis, and observed good spark when I pulled the cord. This left me to believe gas simply was not getting into carburetor.
I removed the bowl and saw it was full of gas. With a container ready to catch any gas, I opened the valve near the tank and observed liberal amounts of fuel spilling from where bowl mounts to carburetor. So, good gas flow to bowl confirmed.
Using carburetor cleaner and compressed air, I blew out and attempted to clean every orifice I could see. I also checked the float assembly and saw the needle valve that allows/blocks fuel into bowl was operating freely. Reassembled everything, and still wouldn't start.
Took the bowl back out and gave the float assembly further inspection. On my unit, there is a large hole in the center of the assembly where the "perforated brass straw" should be sucking up gas. In the bottom of that hole I discovered a brass plug. I didn't spot this plug before because is was totally encrusted in trash. I was able to remove the plug. This thing is about 4mm long and wide. In the center of this plug I discovered a completely clogged hole. I had to actually scrape it clean with a metal pick, being careful not to damage the metal. I then followed up with lots of carb cleaner and compressed air to make the plug and the tiny hole completely clean. I replaced the plug, replaced the bowl, and the generator fired right up.
I wanted to share my story with you because of the frustration I went through taking my carburetor off at least 8 times before finally discovering this tiny brass plug that no one on any of the forums has ever mentioned.
Posted on Jun 25, 2012
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
Briggs and Straton OHV I/c 17.5 hp motor. Starter stays engaged. How do I touble shoot the starter or switch?
it sounds like the solenoid is staying engaged. try using a tester light on the starter.
Jul 15, 2011 | Garden
Engine will not start. no spark. oil level is good. ...
Nov 18, 2010 | Briggs & Stratton Briggs Stratton 30208...
Hard to start Earthquake ardisam 6.0 hp ohv briggs and straton intek 206 has been sitting awhile need to clean carborator or what is ohv and plate in front of carborator. need starting instructions
Why not remove the carb. and clean it out? If it was "sitting awhile" the fuel has died and needs to be drained and renewed. You might have to dismantle the carb. and blow out the jets with compressed air. Don`t touch the OHV (over head valve) cover.
Sep 11, 2010 | Ardisam Inc Earthquake Mini Cultivator
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton 6200 Watt Portable Generator Logo
348 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
