Question about Kitchen Ranges
Kenmore Gas Range handle screws get loose and door falls off
Model 790.7885
5 Suggested Answers
SOURCE: Kenmore Electric Range - Door handle
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Posted on Aug 24, 2009
SOURCE: Kenmore Electric Range - Door handle Original
We had the same problem. We had some tough epoxy that we squirted into the bolt holes, then screwed the bolts in. It took two of us, one to hold the door together and one to screw in the bolts. We didn't use the oven until the epoxy set, but now we no longer have a problem with the door falling apart every time we open the oven door!
Posted on Nov 21, 2009
SOURCE: Kenmore gas range model 790 door glass shattered, handle problem
We have suffered the same problem for the past 3 yrs. We first had the door all fall apart and I screwed it back together thinking that someone missed tightening a screw. Then shortly after the 1 yr warranty was up it happened again. Sears would not help, first told me that there was a recall, then not. After 6 departments and 12 people later they sent me on to whirl pool the manufacturer who said "see sears".
Anyways since we are abandoned by Sears who we trusted (as parents did) we are on our own, here is how I solved it.
After several times of the screw popping out and chipping and stripping the treads in the handle; I too switched out the bottom handle with the top but now at 3yrs old both handles had the threads stripped and chipped and the oven door fell apart during Thanksgiving dinner with the mother law 2009.
The next step for me after another round with Sears with no results (except they said it was common problem) and a letters to Att. Gen. (keep the letters flowing as they are hearing) was to go to the hardware store. I was able to find (not at the main hardware stores, had to go to mom/pa old fashion hardware store) a packet of #10 Sheet metal screws (Stainless steel) 2 1/2" long and a flat washer. This worked. Cost $1.18. Note it does strip the factory threads, so if your present threads are not too bad you may not want do it. You need the washer because the 2 1/2" is slightly too long. 2 1/4" would be a better length but I could not find them.
I would think Sears would want to avoid the bad press by sending all of us $1.18 worth of hardware out. Sears offered to sell me new handles, but I was not about to give them any more of my $.
And I agree it is a very stupid design to have to small handle (where the most stress is) holding the door/glass together.
Note if glass breaks, do not mess around, buy the proper part to go back in.
Posted on Jan 21, 2010
  • 296 Answers
SOURCE: Handle on oven door is coming loose
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Posted on Mar 06, 2010
Range master 110 loose oven door handle
remove door from oven lay on flat surface and remove the screws around the outer edge CAUTION glass will fall out and break if not careful tighten the screws /bolts holding handle and reassemble it .
Jul 15, 2016 | Kitchen Ranges
Elite range
This pertains to model 790 Kenmore ranges, comprised of an oven door handle that is mounted on the door's glass.
Be careful when tightening the oven's door handle. Even slightly over tightening would likely result in the glass shuttering, because tightening the screws pulls in and thus presses the handle against the glass. This is a problematic design in my opinion. I'd rather give up on a couple inches in the width of the glass, than be unable to adequately tighten the screws fastening the handle and risk shattering the glass.
Aug 24, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
No matter how many timew we secure the handle back on it always falls off - it is dangerous!!!!
The hardware stores have a product called Loctite. You apply some to the threads of the screws that hold your handle on. This should stop the screws from loosening, unless your handle is stripped out. If it is then replace the handle. Good Luck, Appliance Specialists
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Electric Range - Door handle Original bolts installed at the factory came loose and dislodged from the door handle.... no problems but this... i can not screw the handle back myself.. i tried......
Sep 28, 2009 | Kenmore 96213 Electric Kitchen Range
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Dec 01, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Regards
Michael
Jan 03, 2008 | Kenmore 96213 Electric Kitchen Range
Handle on oven door falling
Murray...after a DJ here in NY from the '60's!
First, why is the handle falling off? Is it loose or damaged? Most of these handles are only plastic with holes tapped in. If the holes are damaged and you can't fix them, you will have to replace. Most handles are through bolted in the door. You should be able to access those screws from the inside of the door. If not....
How do take a door apart: First locate any screws in the bottom of the door. Remove them. Open the door and remove screws from the sides and inside of door. Get help supporting the outside of the door and note that it will snap shut when you remove any weight from the door. Caution, most door glass is not well clipped in...it may come loose!!!! You may want to take pictures of the inside of the door once you open it. Once the door is apart, locate any fasteners holding the handle and attempt to tighten them. If not successful, you'll need that new handle. Get an extra set of hands to help with removal and reinstallation of that door skin. You'll need 'em!
Nov 29, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
