Question about Toshiba 40RV525U 40 in. LCD TV
TV won't connect to input of cable box when turned on.
Have to go through the input selection to get the TV to come on.
  • 1,238 Answers
Go to your menu and find the antenna setting select cable.
Posted on Oct 29, 2012
Trinitron tv won't come on. says please wait
There may be a issue with the tuner on the set but there is a way around that.
With a cable box with audio/video out jacks connect to the same kind on the rear of the set---go to that input on the set and should see picture and sound---leave set on that input and change/select channels with the box.
Nov 02, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My Toshiba 36AF43 won't get any channels with converter box or anntenna
  • Connect the antenna to the antenna input of the converter
  • Connect the R-W-Y outputs of the converter to the corresponding inputs on the rear of your Toshiba TV.
  • Turn both units on. You should see a converter menu displayed on the TV screen.
  • Select channel scan on the converter. You should see a progress bar displayed on the TV as channels are detected.
  • Scanning should finish by displaying one of the scanned channels.
Dec 08, 2017 | Toshiba 36AF43 36" TV
Mitusbishi WD-52327 tv cannot figure out how to get the digital cable box to come on screen?
Connect RCA wires (yellow, red, white) from the box's "out" to the tv's Input 1 or 2 on the back input panel of the tv set. If you don't have RCA's you may use a RGA- jumper wire (cable wire made into a 4 ft segment by the tech or buy a short cable wire from the Walmart, Target, or Goodwill store) Connect this wire to the "cable in" on the tv and the other end to the "cable out" on the box.ADDITIONALLY make sure you have the right input settings selected on the tv with the input selection you make with the wire connection you choose.
Jun 21, 2012 | Mitsubishi WD-52327 52" Rear Projection...
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
Turns on but blank screen just says no signal. Also blinking red light
If you have an lcd or modern thin screen tv, go into your menu and make sure your input selection is correct. If you're hooking up to a cable network, you will want to select the HDMI input coming from the cable box (HDMI 1, HDMI 2, etc.). This is for the newer cable systems that have the HDMI cable plugged into the tv. If you have the older, bnc connection (round with a wire in it), you will have to select TV or the input.
If all of the input selections are in order, you could have a faulty cable, or a bad cable box. Try to swap the box out with another tv, if available, to verify if the box is, indeed good.
If you have a standard tv, check the cable box on another tv, also, and swap out the cord to check it, also.
Otherwise, if the cable box is good, and the cords are good, you may have a problem with the tv itself, in which case servicing will be required.
Good luck, and hope this helps.
Apr 25, 2011 | Televison & Video
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Toshiba 40RV525U 40 in. LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
