Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
Rfg297aa won't make ice
Ice maker quit making ice. Ice tray in feeder was empty when I pulled it out. Water is working when I choose water but apparently no water is getting to freezer unit. What else can I check or do?
Posted on Feb 18, 2013
Frig wont cool fan not running freezer working
fan is not working thus u have very little cold air circulating into the fridge. check the fan with a multi meter for continuity? it may be out? When u say freezer working? is there an ice build up ? if so u may have a bad defrost terminator or defrost timer, which in turn blocks the fan from working due to ice build up?
Aug 14, 2014 | Samsung RFG297AA (285 cu ft) Bottom...
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
RFG297AA ice maker not working
On my model RF265AABP, it is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out. Yours may be different.
z
Ice maker assembly upside down on bench.
Apr 09, 2013 | Samsung RS2630WW Side by Side Refrigerator
Not cooling
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
The question is too short so i guess that your refrigerator maybe won't make ice & reason for not cooling so i gave this tip.
Have a good day. : )
Apr 17, 2011 | Kenmore Refrigerators
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
My Samsung Space Icemaker makes ice very slowly. I keep hearing a click-click-click and maybe a few cubes come out. I have taken the white box inside the icemaker loose but not disconnected it. I think...
Yes, this is a "known" issue with the Samsung's refrigerators. You need to order a new icemaker. The icemaker will come with a brand new control board with new firmware. Replace both of them and this will fix problem. The control board should be located at the back of refrigerator under back panel
Sep 26, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
Icemaker is not working.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
563 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
