My insignia D300a computer is saying Window can not start because imy windows file is missing or corrupt
  • 27,725 Answers
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
hope this helps
Posted on Oct 29, 2012
sandrew
  • 2961 Answers
SOURCE: system repair
the system need to repair the registry and system files, but to do this you do need a cd, you can use anybodies XP cd as long as it's the same as yours eg Home or Pro. If you are at any time asked for a product key you can use your own number normally on asticker at the rear of desktops or on the underside of notebooks.
Posted on Sep 13, 2007
SOURCE: Insignia D300a restore disc
Go to Best Buy site and order restore cd P/N 900345 for insignia D300A series it cost $28.95 plus s&h comes up to $38dlls. This CD is not sold in store only on line.
Posted on Jan 14, 2009
rockitman187
  • 2559 Answers
SOURCE: "<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Posted on Jun 04, 2009
fixit2k9
  • 55 Answers
SOURCE: windows XP won't start
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
  5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
  6. Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
  7. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
  8. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  9. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
    Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  10. Test the hard drive. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive but you'll want to test it to be sure.
    If the drive fails any of your tests, replace the hard drive and then install a new copy of Windows XP.
Posted on Jun 20, 2009
  • 103 Answers
SOURCE: this acer AX 3400-E4502 , window 7, doing fine
hi there,
well this won't sound good but you are most likely suffering from a hardware failure. It sounds like your video card. this can overheat once and just get worse from there(runs for but 20 minutes or so then dead). so you would have to replace that to fix the first issue.
ok so since you have done a reinstall to a drive that had a kernel(version of windows) that is still present and newer thru updates. the recovery is a missmatch in files.
so you have now made it hard to get to your data unless you have another hard drive(then just do a fresh install to new drive and view old drive for data). as you will need to have a new boot record on the operating systems drive (or clean the old drives boot record with fixmbr this would require much more explanation)
GL
hope this helps
don't forget to vote for me
Thanks
Jammer
Posted on Jul 01, 2011
Windows\systems32\config\system file is missing or corrupt
You can order a new set of disks from the manufacturer or pull out the had drive and plug it into another PC or buy an external hard drive dock . Newegg has them for around $20
Mar 09, 2014 | Insignia Computers & Internet
File is missing
The Error Code 0Xc004e003 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
To fix Error Code 0Xc004e003 Windows 7 Error:
Advanced Computer User Solution:
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Jan 25, 2014 | Microsoft Windows 7 Ultimate, Full Version...
Sound card not installed
This is a discontinued model. There driver can be found at the Insignia website , under support&servcie then Product Specific, then type in the model number of your machine.
I have included the link. Click on Audio Driver and it will download on to your machine
http://insigniaproducts.com/products/computers/D300a.html
Hope this helps
Mar 07, 2011 | Insignia D300a PC Desktop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Im looking for a owners manual for my D300a
http://www.devicemanuals.com/guide/Computer/Insignia/D300a-Insignia-D300a-Desktop-PC-Owner's-Manual-TnpZMU5EST.html
Click on this link Scroll down. Enter the code given there in the text box and click on download to get the owner's manual.
Hope this helps.
Jul 06, 2009 | Computers & Internet
go to www.restoredisks.com, you can get any restore disks that you want.
Oct 10, 2008 | Insignia D300a PC Desktop
Window media player installation
Just reinstall the software. You download windows media player by clicking this site http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx?displang=en&qstechnology=&wt_svl=20513a&mg_id=20513b
once page is loaded select from the pull down menu the type of operating system you are using
Jun 24, 2008 | Insignia D300a PC Desktop
Computers & Internet Logo
David Payne
David Payne
