Question about AEM 2002 Chevy Silverado - 3500, 6.6L Duramax - Brute Force Air Intakes
Transmission fluid in coolant on a 2002 6.6 duramax silverado 3500
I have transmission fluid in my 2002 duramax 6.6 silverado .. how do I flush the coolant system and change out the radiator..I have a new radiator coming
How to fix problem of transmission fluid mixing with engine coolant
New radiator cooler leaking flush both systems tranny coolant
May 27, 2014 | 2002 Dodge Neon
2002 express van 3500 transmission shifting hard with a clunk
The first thing to do is have the transmission tested for fault codes, it is computer shifted, if nothing is found then pull the teanmission pan and replace the fluid and filter.
Oct 30, 2012 | 2002 Chevrolet Silverado 1500HD
2002 chevy 3500 duramax 6.6 ran hot now cranks but won't start
Check spark plugs, leads, distributor cap & rotor arm, fuel pump, fuel filter, coil pack(s), relays, replace any items that are suspect IE Fuel filter which has probably not been changed since new even though they should be changed on all vehicles every 18 months, all of this can be done at home & will save you a lot of bucks in mechanic/garage fees,
Sep 21, 2012 | 2002 Chevrolet Silverado 3500
2002 chevy 6.6 duramax wont start even in warm weather or after motor is warm..... only starts with starting fluid. codes are p0335/p0193/poo87/p0090
The Duramax fuel filter assembly is bad about sucking air. Replace the fuel filter assembly. It comes with a new fuel filter.
I need some good feedback.
Oct 09, 2011 | 2002 Chevrolet Silverado 2500HD
I have a 2002 chevy silverado 3500 with a duramax that was flooded and now i can't get running .I have changed all the electronic modules and fixed all the codes that was found ,changed injection pump and...
From personal experience, You have to unplug every single plug/connector and clean up with electrical contact cleaner. This is a pain in the you know what but, In the end I found about 5 connections that were shorted out, or filled with corrosion. Try this and please let me know how you make out. Please rate answer accordingly!! Thank you
Sep 15, 2010 | 2002 Chevrolet Silverado 3500
When applying brake on2003 chevy 3500 duramax dully power steering is lost. what are possible causes
I think your truck has a hydrostatic break system and it is driven off of the power steering pump. Check the fluid first in the power steering.
Aug 25, 2010 | 2003 Chevrolet Silverado 3500
On a 2004 silverado with a 5.3 I am very slowly losing antifreeze. No visible leak anywhere. What are the probable causes?
(inside the radiator.) trans fluid flows thru a line in to the bottom of the radiator. to keep the trany fluid cool. if that line is corroded inside the rad,coolant will get into your trans, check your trany fluid to see if it has coolant in it. if you do change radiator and flush transmission, note: if it is, the odds are the transmission will not function properly even after you have had it flushed.
Jun 08, 2010 | 2000 Pontiac Grand Am GT
Smoke when idiling
U need to replace your valve stem seals.
May 20, 2010 | 2001 Chevrolet Silverado 2500HD
2002 chevy silverado 3500 crew cab duramax will not start
sounds like a fuel pump/sending unit.. a pump normally just quits with no warning..
Apr 14, 2010 | 2002 Chevrolet Silverado 3500
Location of speed sensor 2001chevy silverado 3500 duramax deisel with allison transmission model year 2001 transmission speed sensor
above were your electrical plugin plugs up on the rear left of transmission. that is your output shaft speed sensor.
Dec 26, 2009 | Chevrolet C3500 Cars & Trucks
AEM 2002 Chevy Silverado - 3500, 6.6L Duramax - Brute Force Air Intakes Logo
73 people viewed this question
Top AEM Tools & Hardware - Others Experts
D. E. Hev
Tom
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
