Question about Frigidaire Gas & Electric Stove/Oven/Range /Cooktop Ultimate Griddle
Meat does not brown in gas oven
Chicken does not brown in 350 oven
  • Official Brand Answer
  • 4,342 Answers
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
Posted on Oct 31, 2012
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
What does code d-o mean
Good Afternoon friend, that's a great question!
From my understanding your Electrolux range is displaying a code of "d-o". The code could stand for open door, could be missing a sequence, or a miscommunication within the control panel. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. Hope this information is helpful. -Matt
Mar 09, 2015 | Electrolux Wave-Touch EW30GS65GS 30"...
Problem with oven reaching tempture setting for bakeing
make sure no one has taken it of and put it on in the wrong spot it may be reaching 350 degrees and you just dont no it
Oct 26, 2014 | Whirlpool Whirpool 4.4 cu ft Gas Range w/
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
The oven for my G.E. gas stove takes forever to reach 350 deg.
Here are the common causes.
1. First check that the bake and broil burners/ignitors are working. If not, you may have a bad ignitor.
2. If #1 is ok, then the burners must be short cycling, that is, they are ON for too short a time then OFF again.
#2 can be caused by either a bad temperature sensor or a failure in the control board.
The temperature sensor needs to be checked by disconnecting and measuring it's resistance.
If the sensor is good, then the problem is in the control board. We repair this particular problem with the controller quite often. If you want, I can have a look at it for you, if you can have it removed and sent to us.
Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | GE Cooktops
Have a kitchenaid gas cook top with the flat cooking surface in the middle for griddling. But its all dark brown and discolored especially around the back. I cant see to get it clean or get the brown...
A few cycles in the dishwasher may help. Oven cleaner on the surfaces (pre warmed if possible). Please do NOT use anything abrasive (no metal scrubs, no steel wool, etc.). Ceramic surface cleaner (Ceramibright?) can be used safely.
Oct 12, 2009 | Cooktops
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
I have a brown brand gas stove and the oven is not coming on stove has no electical cords
hello. i can help. here is the manual for your stove. http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
look on page 17 as it tells you how to light the pilot light.
Jun 05, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
Wolf Oven
Use DeBruce Polish for the stainless steel and smooth cook tops. We get DeBruce at debrucepolish.com
Aug 07, 2008 | Wolf Range 18 in. SPR-100 Gas Cooktop
Frigidaire Gas & Electric Stove/Oven/Range /Cooktop Ultimate Griddle Logo
342 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
