Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
    Guru:
  • 145 Answers
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Posted on Apr 13, 2014
SOURCE: How do I replace the starter rope on a YArd
Thanks for your help, but my friend fixed it today.
Posted on Jun 30, 2009
bbreton
  • 437 Answers
SOURCE: Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Posted on Oct 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My 2 year old Yard Machine 21in 139cc MTD engine
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 03, 2010
  • 160 Answers
SOURCE: I have a Yard Machine
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
Posted on May 02, 2011
  • 708 Answers
SOURCE: My yard machine 21 in
This is a very hard question to answer.
Does this happen throughout running time?
Does this happen only when you start the mower and for a few minutes?
How are you storing the mower, flat or on it's side?
Is there a hole in the side of your mower?
Is the oil leaking between the engine block and oil pan?
Your question hasn't been answered, not because it has no substance, but because no one really knows what the problem is to make a substantial diagnosis. You have to keep in mind that my fellow repair GUYS, as well as myself, can't see what you see, so that makes YOU our eyes.
Try again , be as descriptive as you can , and maybe somebody will answer this question. GOOD LUCK.
Posted on Jul 11, 2011
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Jul 16, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need to replace the pull cord on a 4hp, yard machine, 21",mower
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 20, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
403 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
