Question about Creative Labs ZEN Vision:M Digital Media Player
Will not turn on
When my Zen is plugged into the usb it's on and says docked....but once i remove it from the usb it shuts off and i'm not able to power it back on.
Please Help :)
  • crazytaylor1 Jan 03, 2009
    it's been plugged in for like 24 hours.....still doesn't work...once the usb is disconnected....will not turn on.
    Problem Solver:
  • 5 Answers
Well keep trying to plug it in it should work after a while
Posted on Jan 03, 2009
Creative zen battery indicator problem
Try to reset it. May be it stuck. On my Creative Zen Vision M I do reset by inserting a paper clip into a small hole near a dock connector. Good luck!
Sep 09, 2009 | Creative Labs Zen Touch MP3 Player
When I plug it in to charge the player, it says "docked" as usual, but then it turns itself off and acts like I've disconnected it. It says "Low Battery" and shuts down.
The zen need a full charge... if you have an ac adapter plug it in for at least eight hours. if you don't have an ac adapter plug it in via USB to a DESKTOP computer (not laptop) and try to use a differnt usb cord (creative doesn't always include a powerful enough cord to get the zen out of that low power state)
refer to and look up info on your model to see if anyone else has your issue
May 26, 2009 | Creative Labs Zen Digital Media Player
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
Mar 31, 2009 | Creative Labs Zen V MP3 Player
Zen V Plus Drive not recognized and won't charge
Try going to the control panel - hardware and delete
the Zen [ make sure your Zen is unpluged ] once delete
plug your Zen back in and see if this does the trick
Aug 01, 2008 | Creative Labs Zen V MP3 Player
Zen not turning on after powering up
I had the same problem. Couldn't turn on the Zen and computer wouldn't recognize it.
I took a safety pin and reset it. It works now! Thank goodness!
Apr 28, 2008 | Creative Labs Zen Digital Media Player
It won't turn on manually
I had this same prob. I solved it by holding the on switch down while at the same time pressing a pin into the reset hole. hope it sorts it John Davo
Apr 04, 2008 | Creative Labs Zen Digital Media Player
How to reset Zen v +
Nov 04, 2007 | Creative Labs Zen V MP3 Player
if you are using a fromt usb port- switch to the back usb. The front ports don't always give the zen enough power. Also- look in Device Manager and see if there is a zen listed there- and if it is does it have a yellow exclamation mark? It may not be the zen that is having problems but your computer.
Oct 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
My Creative Zen M won't "dock"
One problem may be that the registry entry for the player is corrupted. You can find out if this is the case by opening your computer's Device Manager (this page tells how, if you're not familiar with it). Look under "Windows Portable Devices" if you have XP or "Portable Devices" if you have Vista, and you should see the name of your MP3 player.
If your player is listed in the Device Manager but has a small yellow warning sign next to it, right click on your player's name and click Properties. The Properties box may say "Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)."
If this is the case, there's an easy fix, that doesn't require any messing with the registry or anything:
--Right click on your player in the Device Manager and click Uninstall
--Unplug your player from your computer when the uninstall finishes
--Plug your player back in to your computer
--Vista will automatically reinstall the driver, and your player should appear in My Computer
Unfortunately this is for Vista. I don't believe XP will reinstall the driver automatically, so you may have to install it manually from your Creative CD. Anyway, what this does is simply uninstall the corrupt driver and reinstall it. It worked for me - hopefully it helps you!
Mar 22, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
26 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
