Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Makita btd142 brake not working
Brake not working
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: bit stuck in quick release
What has happened is the hex part of the bit has twisted slightly making it hard to remove. What I would do if you are comfortable with partial disassembly is remove the quick release mechanish. There is a split ring that comes off first and then a washer and spring, next remove the outer collar and SMALL steel ball from side of chuck. I take a pick (dental tool) and push up or try and twist the stuck bit. Sometimes it takes while but usually this works. Let me know if I can try and help further.
Posted on Dec 20, 2008
My friend just had a problem where the shaft of a socket adapter broke off inside the the driver. Taking the spring assembly out didn't help as it was wedged so he used a screw/bolt extractor (ez out style thing). Drill a 5/32 hole in the broken piece, pound in the extractor and wiggle it back and forth to get it out. Beats buying a new chuck, or whatever that end piece is called on these drivers...
Posted on Jan 25, 2009
My Makita impact driver led light stays on soon as the battery is clicked in. Any idea whats wrong and how I can fix it?
the light is normally activates by the trigger, so either the switch has gone faulty or the wires running to bulb are contacting.
press the helpful button and check link below
Makita BTD142 Trigger Switch Replacement
Jan 23, 2016 | Makita Drills
Makita LS 1212F brake
The brake on these saws is a controlled by the switch; it allows power to only one side of the field when you release the switch thus pulling the motor to a stop. In order to get your brake working again you have to replace the switch with Makita part number 651923-1, Switch TG70B. You can put in a generic switch that fits but the blade will spin slowly to a stop every time you release the switch, which you may have now.
Jun 29, 2012 | Saws
Btd142
Go to the Makita home page, http://www.makitatools.com/en-us/Modules/Home/Default.aspx, and put your model number in the search box to find their page on your tool. On the left side of the page will be the parts breakdown and owner's manual for view or download if they are still available.
Dec 27, 2011 | Makita Btd142hw 18v Compact Cordless...
Bought 2 no BTD142 impact drivers from Makita USA got drop down transformer they just start to charge then tones for broken battery are heard and stop charging, transformer new, batteries new have i done...
these newer chargers do make a tone that can be changed. when the batterys are initially inserted they will make a sound and then when they are fully charged they will make another usually longer sound. you can change it by removing the battery with 5 seconds and reinserting until you find the sound that you like.. I would look at the charging lights before deciding the charger or battery are bad.
Nov 22, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita Saw blade brake doesn't work.
If the model number is right it could be a couple things, I would try and blow the motor housing and area surrounding it with compressed air. Second I would FIRST unplug the saw and remove the brushes and check the condition, if they appear burnt I would replace them, if there is dirt or worn brushes it could cause a problem but before I got deeper into this tool I would recommend checking the date of purchase and seeing if it is still covered under warranty. This a fairly new model for them. If not let me know and I will look at a schematic for this and try and help more in depth.
May 03, 2009 | Makita 10" Miter Saw LS1030N
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 | Makita Saws
Bit is stuck in btd142 driver
the makita impact drivers are picky about the bit that you use. if you use a single sided bit you have to make sure the distance between the channel and the end is 9mm (3/8) and if you're using a double sided bit you have to make sure the distance from tip to channel is 12mm (15/32)
try using a 1/4" wrench on the bit in reverse while pulling the collar back. if that doesnt work, tap the tip of the bit with a hammer with the collar pulled back
Nov 29, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Bit stuck in quick release chuck - makita btd142
Oct 12, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
24 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
