Question about Generac GP5500
Generac gp5500 wil not start - Generac GP5500
How old is the fuel? The carburetor likely needs to be cleaned from gummy residue. Check this video for step-by step. You will need 8mm and 10mm sockets to take off the air filter housing. http://www.youtube.com/watch?v=3FRjw61RCgk
Posted on Oct 28, 2012
  • debjohn82
    debjohn82 Oct 29, 2012
    Thanks Richard. It was the fuel. Changed it the fuel and it started right up!! thanks
GENERAC LIGHT TOWER MODEL MLT6SMD IS BRAND NEW WITH 23 HOURS OF RUN TIME AND WIL NOT START. TURNS OVER AFTER 15 SEC DELAY, BUT DOES NOT START. FULL OF DIESEL AND OIL
hi
it looks that a wire feeding the little solenoid switch come away or damage ( this solenoid switch it turns the fuel on when the engine gets activated )
a// faulty solenoid
b// no electric supply to solenoid
Oct 04, 2017 | Generac Electrical Supplies
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Generator runs,no power at breakers or output plug,has been started and shutdown under load. 5.7 volts on wires coming from stator. All three wires.this is on a motor home.
have the unit checked by an authorized generator repair shop
if it was operating when shore power came back on there is every possibility that the generator or inverter has been damaged from the lack of synchronization of the sine wave
Oct 07, 2015 | Generac 5975 GP5500 GP Series 5500 Watt...
Where is compression release
If you can get it running, run some "Sea Foam" cleaner through it. Sounds like the valves (reed) are gummed up... I don't think there is a compression release on this machine, but you can get the manural at: Generac Power Systems The best backup generator for your home business...
Oct 12, 2014 | Generac Power Systems Generac Gp5500...
Generac troubleshooting
Check that there is not a switch to activate the panel. Next, there is a fuse for the outlet panel as well or a circuit breaker. Check that. If all of that is good you will have to put a meter on all of the wiring points from beginning to end and find out where the voltage stops. Then you have found the component that went bad.
Jul 16, 2014 | Generac Generator. GP5500-Watt Portable...
Engine will not complete a revoluyion
First check:
Check the obvious battery
Remove spark plugs and try, make sure engine is not mechanically bound or seized.
Check the starter motor to make sure it isn't binding up
Sep 14, 2013 | Generac 5500 Watt GP5500 Generator -...
Generac GP5500 Logo
813 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
dennys23601
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
