Question about NEC NP1000 OWIZ136606492101
Np1000 stuck in eco mode
I have replaced the lamp with a new one. Have reset lamp hours and checked the lamp mode is set to Normal. The green lamp light still comes on to show the projector is in eco mode. Is there are reset mode other than the Help button being pressed for 10 seconds on the remote?
SOURCE: Machine will not come on
Hi there
Sounds like a typical Ballast ( lamp's powersupply ) problem.
Posted on Mar 26, 2008
  • 3 Answers
SOURCE: NEC MT820 Projector
Press and hold the power button on the remote control for 10 seconds.
Posted on Jan 12, 2009
SOURCE: NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Posted on Apr 18, 2009
  • 150 Answers
SOURCE: just replaced vt700 lamp. projector still
Try the old lamp again and reset again and see if that works. When you originally replaced the lamp did it give you a warning that replacement was required or did it just stop? I haven't worked on that model before but you may require a new Ballast (power supply ) that runs the lamp (technician job usually)
Posted on Jan 07, 2010
m_peel
  • 76 Answers
SOURCE: I have an NEC VT470.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual.
Good luck
Posted on Aug 05, 2011
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
It is just very dim. The bulb has 500 hours - is it just a bulb?
This projector had a lamp rated at 2000 hours (normal) / 3000 hours (eco mode). It last shipped in August 2008. It is a 3000 lumen projector. It's a reasonable business class projector.
As a first step, it's certainly worth checking your warranty status. Your projector will certainly be approaching the end of its warranty now, however this model was shipped with a 3 year warranty so it may still be covered if the fault is not the lamp. Check now, and log the (possible) fault with your local Hitachi service dept. eg http://hitachiserviceeu.com/support/contacts/contacts.htm
Essentially it is hard to say. You might find that replacing the lamp makes the projector considerably brighter. A new lamp in an old projector does not return the image to a showroom state though due to degradation in the LCD panels, and dirt etc.
If the projector is not displaying any sign of other fault (ie. it will run happily for a decent length of time, and there are no warning LEDs) it might be worth considering replacing the lamp. A new lamp will cost cost around £250 or $250. If you are going to replace the lamp before sending it for "repair" make sure you fit a genuine Hitachi lamp as non genuine lamps can lead to warranty problems.
Feb 15, 2011 | Hitachi Lamp CP-X400 CP-X200 -...
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
Jan 14, 2011 | Hitachi CP-X450 LCD Projector
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Oct 07, 2009 | NEC NP100 Projector
My nec vt48 projector gets hot and turns off. It gives off 3 beeps a few seconds after
This problem and the error beep codes indicate a lamp that needs to be replaced. The correct part number for the lamp is VT85LP. Basically the lamps are rated with a life expectancy of 2000 hours. At the 2001 lamp hour (3001 in eco-mode) the LCD projector will power on, but not display an image, due to the indicator requesting the lamp be replaced and the lamp hours reset (hold the help button on the remote for 10 seconds when powering it on).
Aug 19, 2009 | NEC Office Equipment & Supplies
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Tv only 2 years old
I don't know your set in particular, therefore I will be generic.
On some projection sets, there is an hours counter that is manualy resetable. Make sure that it is reset. If you can have a readout of the amount of hours used on the lamp this will tell you if this needs to be reset.
Normaly, when the set reacts as per your description, there is a cooling problem, or a fault in the power supply.
Also with your model of set, check to see if there are any safety switches that work with the cover or door for the lamp access. With the safety switch option, if the uPC thinks that the lamp is not properly enclosed or installed it will not allow for proper startup.
Jerry G.
Apr 13, 2008 | Mitsubishi WD62628 62" Projection HDTV
NEC NP1000 OWIZ136606492101 Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
