Question about Electrical Supplies
We put oil in our Troy Bilt 030245 portable generator and filled to overflowing as was recommended. Generator started but spewed out smoke and then shut down. Will start briefly now but not continue.
Oil problem?
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 4088 Answers
SOURCE: I have a Troy Bilt 7800 portable generator. It produces no power.
Make sure the generator/alternator is being driven by the engine. Couplers fail often enough to consider the possibility.
Posted on Sep 14, 2009
  • 4088 Answers
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
Posted on Sep 26, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
  • 151 Answers
SOURCE: Troy-Bilt 5550 generator. After starting if I move
improper setting in the fuel needles of the carb. what size is the engine? brand?
Posted on Dec 24, 2009
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
Troy-bilt extenda panel xp 7000 generator paney will not display
My Troy-Bilt XP generator doesn't work it runs but it doesn't seem to be put out any electricity. It's new what could the probelm be
Jul 22, 2012 | Briggs & Stratton 20-Amp Extenda Panel -...
Generator spewing oil
if too much oil it will do this , the oil is pushed past the piston rings , fill to correct level , if it does it with correct oil level the piston rings are gone,
Feb 29, 2012 | Hammering
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
I have a Troy-Bilt portable generator Model 01919 This generator has never been put in service and only started up to test for operation. The generator seems to only run at fast speed and never (...
You may have motor internal problems with governor control. Moving governor arm from engine and see if it operates freely if not try pecking on shaft that does into engine and see if that might free up.
Oct 30, 2017 | Troy-Bilt Garden
Troy bilt gas portable generator not producing
Sep 26, 2009 | Electrical Supplies
Sep 14, 2009 | Electrical Supplies
Jun 20, 2009 | Electrical Supplies
Mar 29, 2009 | Electrical Supplies
Briggs and stratton engine #204412 type #0163e1
I found a parts list for model 204412 at http://www.buysmallengineparts.com/
Jun 30, 2008 | Computers & Internet
Electrical Supplies Logo
222 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
