I can not tune down to Channel 3 on my Panasonic tv combo I'm trying to watch cable tv
    Sergeant:
  • 204 Answers
This TV you need to use the remote and manually press in 03. If you don't have the remote buy a universal remote. They are cheap. GE is best. Sold at Dollar General.
Posted on Dec 29, 2012
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
  • 187 Answers
SOURCE: panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
Posted on May 27, 2009
  • 55 Answers
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Posted on Nov 01, 2009
budmrtn
  • 11361 Answers
SOURCE: screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 06, 2009
  • 1779 Answers
SOURCE: TV has lost channel 3-1. Running auto tuning
Un-plug the set fir 10 minutes then run Auto tuning again, let me know.?
Posted on Dec 24, 2010
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
VCR Recording OK but cant see tape content
VCR may not be tuned to the right channel. If you are using your VCR for the tuner then your tv is set to channel 3. Check your cabling again as well. From the wall to the VCR. From the VCR to the TV. You also need to make sure that you programmed the VCR for all of the channels. Just like you would for a TV.
Jan 20, 2013 | Panasonic Nv-Vp32 Dvd Vcr Combo 110-220...
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
May 12, 2010 | Panasonic PV-C1350W Combo
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Nov 07, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Can't tune cable box to channel 2 to set up TVGOS
then you can try channel 3 or 4 if that does not work then you have to replace for a latest tv that does not use cable box.thes out of style
Mar 02, 2007 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
