Question about Tatung V23CLTT 22.92 in. LCD Television
Tatung V23cltt won't turn on
My tv stopped working, not responding when I press the on/off button or turning on but the power light flicking while making a steady popping sound but no picture. I read on another post that it could be the power supply circuit board. I ordered and replaced the part. The tv worked great for a couple of days and now is doing something similar. Won't turn off or on via the button on the tv. When it does turn on, no screen just a blue power light. I've tried unplugging the power cord to reset the monitor but it doesn't seem to be working, again.
3 Suggested Answers
  • 3422 Answers
SOURCE: Tatung Power Supply Repair
Can u tell me very u live and whats pincode of your are so that i can solve ur problem..
Posted on Feb 06, 2008
  • 6 Answers
SOURCE: Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Posted on Oct 21, 2008
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Menu button stopped responding
If only one button does not work at all or all do not work the unit may have a lock out feature that would be explained in the owners manual.
Apr 10, 2012 | Vizio Televison & Video
I need the small card that holds the male coaxial connector for the TV antenna on the back of a V23CLTT Tatung television.
You can get one from contacting customerservice@tvrepairworld.com they had a tatung model arrive yesterday as I bought the power board out of it so contacting them they should still have the Cable input board for that model.
Apr 02, 2012 | Tatung V23CLTT 22.92 in. LCD Television
When plugged in, my tv automatically starts clicking between the on and off light. The picture and audio stay off. It makes a slight buzzing noise. What may the problem be?
The power supply board is dead.The buzzing sound,mean those transformers shorted and dying.Power supply board, that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 06, 2010 | Tatung V23CLTT 22.92 in. LCD Television
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Tatung wont turn on
    Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
    Can not program remote to TV
    I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON DON'T JUST PRESS IT ONCE LIKE A LOT OF SITES SAY TO DO.  I HAD TO PRESS IT A FEW TIMES, AND THEN IT TURNED THE TV BACK ON AND THE REMOTE WORKED!!! MY REMOTE WAS THE RCA RCR312W...TV IS AN OLDER ORION
    1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
    2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
    3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
    4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
    5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
    6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
    8. To save the new code, press and release the STOP button.
    9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
    May 15, 2008 | Tatung V23DLWX Television
    TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
    I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
    P/N: 6693006610
    Model: HOAU242001(A)
    Scheda Inverter PWB-0656-03
    Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
    Tatung V23CLTT 22.92 in. LCD Television Logo
    44 people viewed this question
    Top Tatung Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    CoppellTVRepair.com
    Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
