Question about Black & Decker Black Decker Circular Saw Cs1010 In Case
How does my cs1010 fit back in it's case
How do i fit my cs1010 black and decker circular saw back in it's case. I've done it before, I just can't for the life of me get it back in
  • 17 Answers
SOURCE: I have a 2hp black and decker circular saw. Went
If the motor is 3 phase (which it may be if it is 2 HP) , it will run backwards if 2 of the wires are traded position. You may have changed the wires in the plug if you replaced a plug.
Posted on Jun 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: bought my black and decker circular saw in july
you would need to send it to a Dewalt service center or any authorized Dewalt service center for warranty repair, The exchange period is usually 30 days. If you need to give me your city, state and zip and I will try and find one close to you.
Posted on Oct 28, 2009
rowdy45176
  • 2176 Answers
SOURCE: I can't tighten the blade on the saw.
are both flanges in place and on correctly?? That would be the first thing that I would look for.
Posted on Dec 30, 2009
al_kupchella
  • 843 Answers
SOURCE: How can I change the circular saw in my Back &
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Posted on Jun 18, 2010
Testimonial: "Thank you very much; more or less what husband had tried to do, but none the less he's going to try again, according to your instructions. Will let you know the result later. J"
rowdy45176
  • 2176 Answers
SOURCE: Need a parts manual for a black and decker
you can get the parts explosion from dewaltservicenet.com, but I will save you some time the armature and most parts for this saw are obsolete no replacement. I checked with another site I use and they don't show that part either. Sounds like time to replace it.
Posted on May 12, 2011
My black a nd decker circular saw just stopped functioning midway inuse
It is hard to say at this distance what is wrong. If it is oldish, the motor brushes may be worn down. It could be that a wire has come loose from a terminal in it, or a contact has broken in the on/off switch assembly. All those things have happened to me at one time or another.
Jan 18, 2015 | BLACK and DECKER POWER TOOLS Black And...
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Where can i find a manuel for a black and decker circular saw manuel
http://www.powertoolspares.com/tool/black-and-decker/spares-and-accessories-for-ks850-circular-saw/ks850type1/spares/
If you're in the US just call a service center.
http://dewalt.com/Find-Service-Center.aspx
Apr 18, 2012 | Black & Decker Saws
Manual for black and decker circular saws #7301 type A
Okay im restoreing an old Black&Decker circular saw 7 1/4 volt 120ac Amps 9.0 Type A Rpm 4900 now im putting it back togather and i need help Ive got evrything else down patt just what the saw blade sets on there's like a lil motor that is togather where the blade goes and has teeth all around it and connects to the big motor it has a pin there ive found that just when i put it all togather there's a gap there and dont know why ive took my time and went from one screw to next easy and still does the same thing i thought maybe something was in the way where the two plates screw down but there is nothing in the way any idea's help me please
Jan 12, 2012 | Black & Decker Saws
I have a black and decker CS1000. How do you tighten or loosen blade. There is no spindle lock that I can find.
If you can't find a spindle lock you can unplug the tool and find a piece of wood and put the blade against it and loosen and also tighten the blade, but most newer saws have a spindle lock located in the gear housing somewhere.
Sep 18, 2011 | Black & Decker CS1012 7-1/4" 12 Amp...
Bought my black and decker circular saw in july 2009 stopped working and still has warranty Ace hardware where I puchased the saw will not exchange saw says I need to send it to the company but, I didn't...
Oct 28, 2009 | Black & Decker CS1012 7-1/4" 12 Amp...
Black & Decker Black  Decker Circular Saw Cs1010 In Case Logo
41 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
