Question about Coleman Powermate Proforce 2500 Generator
How to drain oil from Coleman Powermate 2500 Premium Portable Electric Generator. Briggs & Stratton Quantum XTE 50.
  • 76 Answers
SOURCE: I have a coleman powermate 2500 and have just
HOW MUCH CAME OUT ALSO ANYTHING UNDER 16 H.P. GENRALLY TAKES TWO QUARTS BUT START WITH 1 1/2 AND CHECK TELL ME THE BRAND OF MOTOR AND HORSE POWER AND I SHOULD BE ABLE TO TELL YOU EXACTLY
Posted on Jun 24, 2009
CarlGehrke
  • 169 Answers
SOURCE: checking the gas and oil levels?
There isn't really a guage to look at . What one does is to take out the plastic plug on the side of the engine and with the engine cold and level make sure that the oil level comes up to the lowest thread where the plug screws in.
You really should have a manual, so if it's missing look here for which ever "PM" number is printed on the tag on the end of your generator.
Regards,
Carl
Posted on Jan 07, 2009
  • 373 Answers
SOURCE: Coleman powermate 2500 won't start and gas is leaking out of the
it sounds like mine I think it is the carb is clog up
I am still working on mine
Posted on Feb 05, 2009
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
stunt driver
  • 5 Answers
SOURCE: Coleman powermate 2500 generator :
To what I know about this model - it IS NOT inverter type. Electrical motor works pretty much like car alternator with out reftifier. The ONLY magnet on rotor is a small, 1x2 initiation magnet, that helps to start the induction current. After that, induction current thru rotor is controlled by AVR (automatic voltage regulator) in a way, that output voltage stays at needed level.
The fact that you read 2.0 volts on output - tells you that your initiation magnet is OK. One of few things went wrong, in probability order: winding on rotor, AVR module, winding on stator, brushes woar out.
Take back cover off from electric generator part, use voltmeter to measure continuity on stator (2 or 3 poles, must be within 50 ohnm), continuity of rotor thru brushes ( normally within 100ohm). If broken - have to restore windings. It is DIYable for rotor, but hardly possible for stator. If those are ok - most probably your AVR is dead, you can not test it yourself, so get a new module to try (but try to make arrangements for return, if there it was not the reason).
Just fixed Champion 3500 generator myself, purchased for $50 as broken.
Posted on Jan 13, 2010
Looking for a carb for a Coleman Powermate 500/6250 generator with a 10hp Briggs and Sratton engine...any suggestions?
As it is a Briggs Engine most quality Briggs dealers can get the carb. It isn't special to Coleman I don't believe.
Oct 08, 2013 | Coleman Powermate Premium Plus 6250W...
I just seperated the tapered crankshaft from the rotor of my coleman generator ( coleman powermate 2250 with a 5hp briggs and stratton engine). I applied PB blaster, and hit the end bell with a dead blow...
No there is not a key of any sort between the rotor and crankshaft, to verify you will not find a keyway to put one into on the shaft. Just the end bolt with washer holds it on.
Jan 19, 2011 | Coleman Powermate Premium Plus 6250W...
I am in need of prices of briggs and straton gas driven pump powered by a 5.5 hp engine
Hi , you did not say what country your in but a rough price for a new one is 900 dollars .
The link below is to a pump sales site
http://www.waterpumpsdirect.com/Briggs-&-Stratton-073017/p3185.html
Aug 08, 2010 | Coleman Powermate Premium Plus 6250W...
Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Jul 16, 2010 | Coleman Powermate Premium Plus 6250W...
How do you take pull cover of briggs and stratton portable generator 5500w to7250w
There are 4 bolts in total that must be removed. Two of them close together at the top of the pull cover and two at the bottom in the 4 and 8 O'Clock positions.
Mar 07, 2010 | Coleman Powermate Premium Plus 6250W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Misplaced User Manual for Coleman Powermate 6250
I would run a search on line for your model number. I will look and let you know.
Feb 02, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Proforce 2500 Generator Logo
296 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
