Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cable connection is broken
The connection is loose
    Top Expert:
  • RCA Master
  • 14,553 Answers
It can be replaced but average is over 100 dollars---if have a cable etc box with video outputs connect them to one of the rear audio video inputs and bypass the cable fitting----even if have to pay for a box that is cheaper than fixing the fitting (better picture and sound as well).
Posted on Oct 30, 2012
How to make a backfires in discover 125m bicycle?
Hi, Anonymous and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 04, 2015 | Motorcycles
Gas gauge flutters backfires when starting
Hi Anonymous, and the usual suspects are:
1. Loose, corroded, or broken battery cable ends inside the cable harness especially the "NEGATIVE" cable at both ends.
2. A severely drained battery.
Oct 14, 2015 | GAS Motorcycles
Motorcycle won't start. Stalled out, backfired trying to restart, now nothing?
Hi Guitarfield, and the usual suspects are:
Apr 17, 2015 | Motorcycles
My 86 shadow vt500 was running perfect n all of a sudden it started backfiring n evn stalled out on me. What's wrong?
Hi David, and the usual suspects are:
1986 Honda Motorcycle Service Repair Workshop Manuals
Jun 23, 2014 | 1986 Honda VT 500 C Shadow
Back firing
DOWNLOAD 2001 Aprilia Pegaso 650
Apr 22, 2014 | 2001 Aprilia Pegaso 650 i.e.
Low speed esitation
DOWNLOAD 2003 Aprilia Rst 1000 Futura
Mar 10, 2014 | 2003 Aprilia RST 1000 Futura
Does aprilia sr 50 2005 have a cdi connected to throttle cable in cable u stop it from starting if its broken ?
Hi Anonymous throttle only goes to carburetor and oil injector and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
DOWNLOAD 2005 Aprilia Sr 50
Nov 04, 2013 | Aprilia Motorcycles
Backfire carb
Hi Binuya, and the usual suspects are:
Untitled Document
Jul 03, 2013 | 2009 Adly Thunder 125
]98 zx1100 wont idle and backfires when starting
Hi Terrance, and the usual suspects are:
1998 Kawasaki Motorcycle Service Repair Workshop Manuals
Nov 17, 2012 | 1996 kawasaki ZZR 1100
My 99 r1 backfires and reves hi and get hot what do i need to do
Hi Mokell, and the usual suspects are:
1999 Yamaha Motorcycle Service Repair Manuals
May 08, 2012 | 1999 Yamaha YZF-R1
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
14 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
