Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Broken lightbulb won't come out of refrigerator socket
Bulb shattered, leaving pieces around rim. I tried the potato method, it just cut through the potato instead of grabbing it. I then broke off all the remaining pieces of glass, leaving just the rim. Potato still just turned without grabbing on. I then tried the next method of prying the base away enough to get needlenose pliers a grip. Piece of base came off with pliers. Tried on another spot but I cannot get the base to move in any direction ( I know it should go counter-clockwise to come out).
  • tsrose Jan 03, 2009
    Thanks, I'll try it. Hope the epoxy dries since it is inside the fridge.
  • 43 Answers
I had a similar problem with a kitchen bulb a few years ago. I had to put some epoxy in the socket, stuffed a rag in there, then bent the rims inside like a star with a needle nosed plier. I let it dry then it twisted right out. Hope this works for you!
Posted on Jan 03, 2009
How to get a Broken lightbulb out of the socket
Turn off the electricity. The old method is to jam a potato into the socket and twist. I use a pair of needle nose pliers.
Feb 13, 2015 | Cars & Trucks
WANT T REMOVE BASE OF BROKEN BULB STILL IN SOCKET RANGE
Unplug the oven. Take a potato and cut it in half. Jam it into the socket as far as you can. Now unscrew the broken socket by turning it counter-clockwise. The potato will form to the inside of the socket and twist it out.
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Light bulbs in built in microwave have come apart when we tried to unscrew them for replacement. How can we get the broken end of the light bulb out of the sockets?
Most Samsung microwaves use a bulb and bracket assembly that is meant to be replaced as a unit, not disassembled (see image). If the bulb base was secured using epoxy or some other means, it may not be possible to remove without damaging the bracket.
That said, you can try traditional methods for removing broken light bulb bases. Remember to always unplug the fixture/appliance, or shut off and mark the breaker serving it, before working.
A cut potato or carrot can sometimes be pushed onto the broken glass left in the base, to provide a handle for unscrewing the base. On smaller bulbs, I have successfully used the eraser on the end of a pencil.
If the bulb was really stubborn, I would probably try filling the base with a hot glue gun, then pushing a screwdriver into the soft glue. Once the glue hardens, turning the screwdriver should unscrew the bulb base (if it is at all possible).
As you may have discovered, pliers and the like tend to just break off small pieces of the broken glass bulb.
Jul 13, 2011 | Samsung Microwave Ovens
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb broke off in fan light how do I remove?
If the glass is broken and there are sharp pieces sticking out you can use the potato trick. Cut a small potato so you have a flat end, make sure the power to the fan light is turned off, and push the potato onto the broken remains. Then you can turn the potato to unscrew the base and just toss the whole thing in the trash. Wipe off the socket and you're set for a new bulb.
If the old bulb broke off clean so that only the base is left in the socket, you'll need to bend the edge of the base inward a little with a small screwdriver. Then grab the base with needle-nose pliers and unscrew it from the socket. Again be sure the power is off before working on the light.
Mar 15, 2010 | Hampton Bay 48670 Flemish Pewter Finish...
Cannot remove broken bulb from rangehood
Hello. cut a raw potato so that you have a large piece that will fit into the area where the broken bulb is situated. Jam that potatoe right into the broken bulb and twist it out. Remember it will twist out by turning it counter clockwise. [right is tight, left is loose]. Joe
Mar 11, 2010 | Magic Chef CMV1000B Microwave Oven
Lightbulb has boken off in socket trying to remove it from ceiling fan light fixture
try this. turn off electricity, take a raw potato and push it up into the socket, then use the potato to unscrew the bulb, no kidding , this has worked.
Nov 10, 2009 | Hampton Bay 24002 Ceiling Fan
Freezer broken lightbulb
you can usually take a potato and screw the broken bulb out and find a new one home depot lowes or walmart
Apr 24, 2009 | Magic Chef CTB1521 Top Freezer...
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Broken light in socket
Make sure the power is off!!
Get yourself a potato, and cut it in half, yes, a potato.
Use the flat cut side, and push it towards the broken base, while turning the potato counter-clockwise.
Feb 07, 2008 | Video Game Consoles & Games
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
265 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
