Help me out in connecting a second PATA hard disk
i connected a second PATA hard disk but i cant boot my computer.''NTLDR missing alt+cltr+del to restart'' is shown. in BIOS i cant change the hard disk priority and boot priority.PATA hdd is shown havin the highest priority and i cant make my SATA hdd as the first priority
  • 1 more comment
  • Nat Miller
    Nat Miller May 11, 2010
    Internal or External? Is it set to master or slave? Is your bios set to see either SATA or PATA? It looks like you computer is trying to use the drive you just installed as the boot drive. What brand is your drive? Western Digital and Seagate/Maxtor have tools to set up your drives.
  • chrispm May 11, 2010
    Have you tried updating the BIOS of your motherboard? Waht make and model is it?
  • pas_sal1990 May 11, 2010
    Have you tried changing the pin configuration on the pata hard disk drive to slave, and try putting the hard drive on the second connector of the ribbon
  • 28 Answers
Ntldr is file important for boot up and is present in main boot drive, so you can copy it from your sata hard drive to pata, it would at least boot up, also sometimes there may be a req of changing more than one bios option to boot from other drvi, try it
Posted on Jan 04, 2009
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Feb 19, 2011 | Microsoft Computers & Internet
My Averatec 3200 series won't boot up. It says "NTLDR is missing Press Ctrl+Alt+Del to restart" Pressing ctrl+alt+del doesn't help. What, if anything can I do?
The NTLDR is the boot loader of Windows - if it's missing the OS can't boot. The only reliable and easy way to fix that is to do a Repair install - everything will be kept and the missing files reloaded.
Nov 27, 2010 | Averatec 3200 Notebook
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
NTLDR is Missing
NTLDR is missing
Causes:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
NTLDR is missing Press Ctrl Alt Del to restart
The issue is your system is not loading off of the boot drive- check for usb keys, floppies, even sometimes cds can cause the issue. If that does not work, you'll need to get your copy of windows, boot to that disk, and run a chkdsk /r in the repair option. If that does not work, you will need to reinstall Windows.
Oct 17, 2010 | Acer Computers & Internet
Ntldr is missing.... when i start my computer, it only shows NTLDR is missing press ctrl+Alt+Del to restart (this is on windows XP) please help... thanks
First check to see if you have a floppy disk in your floppy drive, if so remove it.
Second check if you have a CD disk in the CD/DVD drive, if so remove it.
If there are no disc in the drives, then the ntldr file is missing or corrupted and needs to be replaced. Please follow these instructions :-
Feb 04, 2010 | Compaq Presario R3000 Notebook
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
NTLDR is missing
Causes:
Sep 10, 2009 | Computers & Internet
Ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
NTLDR is Missing
NTLDR is missing
Cause:
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
to fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
c:\exit
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Mar 09, 2009 | Fujitsu Siemens Computers & Internet
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
