Question about Power Probe 3 Combo Kit with Gold Test Lead Set
Need instruction manual for power probe 3
    Master:
  • 683 Answers
After by by passing immoboliser on '94 ford probe,I have feed to the distributor but no spark at plugs
bypassed its immobiliser ...
yep that would be right
wont have spark at the plugs yet
i dont think fixya would like instructions given out to sort your problem
tow to the probe an auto electrician
you will need a full engine bay loom wiring diagram
other ECU wires need power at crank
the crank angle sensor has to have power feed
the injectors and fuel pump also need power
May 18, 2016 | 1994 Ford Probe
Is there a way to reset my oven?
I am not sure how technical you or anyone in your household is and you didn't give a specific oven model, so I don't think anyone can give you detailed instructions on how to do this.
I would disconnect the oven from power/gas/etc and open the cover. I would look for the wires coming from the probe jack and disconnect them from the circuit board. I would then reconnect the oven and check if that resolved the issue. If that did not resolve the issue then I would call 3 repair services to get an estimate based on the error.
Based on the issue including that the oven is stuck on warming, I would not be surprised if an entire circuit board needs to be replaced.
Nov 13, 2017 | In Microwave Ovens
Low water cut off
The LWCO is designed to shut off the power on the control circuit if the probe ever looses the constant ground it is reading by being submerged under water. If your LWCO trips it could indicate your are either in a low water condition or that you have excessive calcium or mineral that is coating the probe with a layer or thickness around it which is preventing it from reading the ground through the water and will trip the board on a false low water signal. It would be best to pull out the probe and clean it with emery cloth to remove any hard water buildup from the rod. You can also check the board electrically by removing the probe wire from the probe itself and manually grounding it to the tank or jacket to simulate the ground signal, after which hit the reset button. If the board does not reset you may have a board issue or there is no power going to the board in the first place.
Feb 10, 2014 | Mr Steam CU750AB3 Commercial Steam...
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
    This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
    Aug 08, 2010 | Microwave Ovens
    I Lost the instructions for my GE profile Oven probe. Need advic
    I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
    Nov 25, 2009 | GE Profile JT952 Electric Double Oven
    Power Probe III
    dear Mark,
    the screen shows "CB", not C8. Stands for Circuit Breaker. This means you have overloaded your Power Probe 3 and the internal thermal fuse has blown. You can simply reset it by pushing the button on the right hand side of the Power Probe.
    Regards
    Werner Klaassen
    Coplan Europe
    Feb 27, 2009 | Power Probe 3 Combo Kit with Gold Test...
    Cpu temp probe
    probe needs to be between the cpu and cooler and the feeder power needs to be checked for proper AMPS and volts. lala linda
    May 27, 2008 | Aerocool CoolWatch Fan Controllers
    Help On Your Fix Please
    The instruction manual says that "PF" means "Probe Failure", that the probe is damaged.  The solution in the manual says to contact the service centre.
    Customer Service:  800-322-3848  US Customer Service: 888-335-6644 Canada
    May 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
    Power Probe 3 Combo Kit with Gold Test Lead Set Logo
    1,144 people viewed this question
    Top Power Probe Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Power Probe Measuring Tool and Sensor Expert? Answer questions, earn points and help others
