Question about Teac LT-1 Clock Radio
TEAC LT-1 AM/FM Receiver w/CD Player & TEAC RC-910 Remote COntrol
The Remote Control no longer works. I have replaced the batteries (several times). The remote control function became intermittent and then failed entirely. I do not know if the problem is with the RC-910 hand held remote device or with the signal receiver in the LT-1 unit. Can you help?
SOURCE: Volume control does not turn volume down.
I have opened the same unit up. The volume control knob moves a plastic paddle against a right & left micro switches. The paddle is connected to the knob by a very thin piece of plastic which breaks very easily. I tried to glue a different piece of plastic on , but it only worked for a little while. It was a pain to assemble & reassemble the unit. I do not recommend trying it. Just buy another remote (about $35.00)!
Good Luck
Posted on Apr 30, 2010
Bose Wave radio
this is a power problem.
leave the unit unplugged for one night and then try switching ON
Oct 01, 2008 | Bose Wave Radio
CAN REMOTE BE REPLACED?
yes, you can get an original, or buy a learning remote and teach it to be your teac remote.
Alternatively why not let a friendly tech see if they can refurbish or improve the original
TEAC LT1 Remote Control
Estone Brand New DC 3V Mini Learning Remote Control RM L7 Universal
Caikote Conductive Coating Key Pad Repair KitMCM Part 200 315Caig...
Jun 27, 2014 | Teac LT-1 Clock Radio
How do i change the time on my Teac SLD80 radio/cd player?
I think this is the user manual for your device. This should help you with any issues your having. http://www.manualslib.com/manual/665480/Teac-Sld80.html?page=1
Apr 28, 2014 | Timex (T307S) Clock Radio
Cd player reads no disc when disc is inserted.
if all cds are not recognized try cleaning the optic eye with special cleaning cd
Apr 23, 2014 | Teac LT-1 Clock Radio
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
Oregon scientific IWA 80055 Outside temp won't display and I have replaced the batteries on the sending unit and it blinks two times every few seconds.
I have the same unit (IWA-80055) and after not finding anything helpful on the net, I just messed with it until I got it fixed. Here's what to do:
1. Take the cover off the back of the remote sensor.
2. Set the chanel to ch.1. (I tried all three but only ch.1 worked for me).
3. Use several tools. (i.e. a stick, needle, what ever you can but you need two) and hold down the reset button on both the sensor and the clock. (at the same time.)
If done right, it should only take a few seconds to start.
The outside temp is delayed at first. Be patient.
Jan 31, 2010 | Oregon Scientific Lwb0997110113004...
Volume control does not turn volume down. Lost remote control CD Receiver LT-1
Good Luck
Dec 07, 2009 | Teac LT-1 Clock Radio
Remote control problem
Replacement remotes for my AWR1 were $10 from Bose. Order online; receive by mail. I just bought two.
Jun 01, 2008 | Bose Wave Radio
Teac LT-1 Clock Radio Logo
688 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
