Question about RCA R52WH73 Projection Television
52 inch rca hdtv projection
The bad 3-D and bowed screen and doubled letters.... Where is the fly-back. and the 3 red triangle fuses? can you walk me through this?
  • RCA Master
  • 5,138 Answers
Yes, I sure Can how much money can you send am Broke? First board on bottom left is Deflection board / Board next to it on right side is SSB board has turners on it. OK go to menu then setup look for convergence if its not there/ then you have open Fuse FL231 ON right side of FBT flyback transfomer there is 3 in a roll small square brown looking caps but they are fuses. Will be right in front of you.on board. FBT is gray/black has 2 wires coming out from it. red'/bl
Posted on Jan 08, 2009
It has curved screen and double letters
You have a defective deflection board. Normally there is a three brown fuses next to the fly-back transormer and one of then must me open for over current. You need to replace the fuse and resoldered all the Fly-back transformer pins...Good Luck
Aug 23, 2011 | RCA HD52W59 HDTV Projection Television
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Double vision on the 52 inch tv in red and the top sags down a couple of inches like a smiley face smile
Resolder the connections on the high voltage transformer. There are 3 fuses mounted to the right of this transformer. They look like 3 brown boxes. Replace the center one if its open. ABOUT 1/2 AMP pc mount fuse pico fuse will do. Common failur eon this tv.
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
beside fly back you will se a 3 smals fuses ( red color), one is open ( 1-2 amp), and resolder fly back terminals.
Apr 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Colors seperating and Screen bowing
The convergence circuit is not working. There are bad solder connections on the sweep board and a small fuse is open. this is not easily done yourself unless you have a technical background but an RCA tech can fix this easily.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV all blured and screen concaved on all sides
Look,followsteps and you wil repair this set. Disconnect main board ( fly back), take care about connectors. Under fly back you will see loose connections, resolder and that's it Am sure this is your solutions.You need do this soon, because fuse will be blown if keep blink picture, Thank you
Aug 08, 2008 | RCA P52926 52" Rear Projection Television
Picture convergence and double lettering
there is a bad dioded rca part # rca 259638 its in the convergence part of the tv it has to be replaced
Aug 03, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WH73 Projection Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
