Mt samsung washing machine drain valve is always On
Dears.. I have Samsung WA15P9 Washing Machine with a Top Load. The drain valve got burned and I replaced it with the same model fro the agent. After I replaced it, the new one get working but always on. It should get OFF when the washing machine start washing but it keeps drain the water without stopped. Any help??
Benimur
  • 6966 Answers
SOURCE: repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 21, 2008
SOURCE: washing machine
wont spin
Posted on Dec 08, 2007
  • 46 Answers
SOURCE: Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
Washing machine stop draining and not spin drying
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 21, 2011 | Samsung Washing Machines
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
heatman101
Aug 11, 2011 | Samsung Washing Machines
Samsung energy star silver care will wash wont spin
heatman101
Apr 01, 2011 | Samsung Washing Machines
Hi my washing machine samsung WA10U3 top load. After wash always filter check. Why?
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Feb 06, 2011 | Samsung SW62ASP Top Load Washer
My washing machine isn't draining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 22, 2011 | Samsung WF203ANW Front Load Washer
Wont drain water
heatman101
Oct 16, 2010 | Samsung WF218AN Front Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
