SOURCE: Canon FS200 won't fully initialize 32 GB SDHC card
I've fought with this and long story short here is how I finally got my 32GB card to work with my Canon FS200 camcorder.
Turn off camcorder
Insert 32gb card
Turn on camcorder
Make sure you are on Photo Only Mode
Initialize card (not full initialize)
Turn off camcorder
Remove card
Re-insert card
Turn on camcorder
Switch to Photo Only Mode
Take a picture
Switch to Movie Mode and take video
Sounds crazy but I tried MANY other ways and this is what worked for me. Only thing I can think why this works is the file system is more basic on photo only mode and taking a picture lets the camera know the card is working - doesn't make sense, but I guess it doesn't matter as long as it works.
Hope this helps!
SOURCE: I have a canon fs 200. How do you delete information from memory
use a memory stick reader & delete the files/info in your computer
SOURCE: card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
SOURCE: I downloaded clips from the memory card of my
this is more likely to be an issue with your computers monitor settings rather than the video itself. try burning to disk and viewing on you TV you should find no problems
SOURCE: I put the memory card from my Canon FS200 video
You definitely have anti-virus installed in your system (Computer), As a result system prompted for SCAN & fix due to possible virus or worms found in your device (Canon), At the moment you click that "Do you want scan & fix canon", the system have cleared/deleted the virus or worm infected file, In the result you are unable to find the video files again or If it is there it will not run. I would recommend you to formate your Memory Card and then use it. There is no way to recover that video again.
Hope this will help,
Thanks..!!
