Question about VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - White
VITRA TOILET TANK TO BOWL GASKET - VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - White
5 Suggested Answers
  • 30 Answers
SOURCE: Vitra elongated Toilet
Sounds like you need to replace the fill valve assembly. It is not expensive or difficult, just a little messy
Posted on Jul 09, 2009
projdoc
  • 2237 Answers
SOURCE: VitrA #5055 toilet why will it not stop running
the flapper is not closing all the way in the tank. if, when the handle is at rest, the flapper chain is too taut, the flapper is not closing all the way. so loosen the chain. if there is slack, the flapper is not making a good seal and is letting water through. or if in the tank the water is going over the standing up overflow tube, you need to adjust the float. if you have the ball float, lift it up slowly and see if the water stops running. if not, replace the ballcock (valve where the float is attached. if it does stop, unscrew the ball a little or bend the ball arm down a bit until the water stops short of the overflow. if you have the shuttle float, do the same test. if the water does shut off, adjust the shuttle accordingly.
Posted on Nov 13, 2009
  • 33 Answers
SOURCE: VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Posted on Aug 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: WHERE CAN I GET TOILET HANDEL BAR FOR VITRA BRAND
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Water level in new toilet bowl to low
water level in the bowl( pan) is determined by the height of the sewerage pipe level that it is connected to and is fixed by design and style of the pan
unless you are on about the water level in the cistern( tank) which you can adjust yourself
Nov 17, 2015 | VitrA Aria Toilet with Elongated Bowl/...
When the toilet back is removed does the seal need to be replaced?
Yes the rubber gasket between the bowl and the tank should be replaced, because it takes the imprint of the flush valve and ther's no way to make sure it goes back in exactly the same place, so it could leak, They are not expensive and should be replaced, along with the tank to bowl gaskets.
Jul 12, 2014 | VitrA Aria Toilet with Round Bowl /...
How to install a toilet
Things needed; set of johnnie bolts, wax ring, water supply tube, open end wrenches.
insert the flat head of the johnnie bolts into the groove of the floor flange so the threads are pointed straight up. Install the wax ring directly onto the floor flange. Set your toilet bowl down on top of the wax ring so the johnnie bolts stick up through the holes at the bottom. Install the washers and nut to secure the toilet to the floor. Depending on the type of toilet, you may or may not need to manually install the tank to bowl gasket and tank to bowl bolts. Set tank onto bowl and tighten the bolts. Usually a 1/2" wrench. Do not over tighten because the porcelain will break. Install the water supply to the bottom of the tank and then tighten it to the water shutoff valve. Install the seat, and your all set.
Apr 09, 2014 | VitrA Home
I have a 4.8 lt flush vitra toilet when i flush hardly any water goes in the bowal to clean the sides of paper
These new style toilets are this way by design. It is designed to use less water, thus helping the. Ecology and your water bill. In effect what is happening is that the trap is lower in the bowl , thus not letting the level of water be as high in the bowl. Now matter if you pour a gallon of water to try to fill it up, it will run out until it reaches that level in the bowl.
Feb 25, 2013 | VitrA Aria Toilet with Elongated Bowl/...
Is it possible to replace just the cistern instead of the entire toilet set? I have had water leaking problem in my toilet. The water is running from cistern to the bowl whenever the cistern is fille
It is likely that the leakage is being caused by a worn-out flapper or seal (the part the flapper seats on). You can buy after-market kits that have replacement parts. What is the make and model of your toilet?
Nov 30, 2017 | VitrA Aria Toilet with Elongated Bowl/...
Hi, Just moved into an apartment with two vitra retro toilets. As soon as you start to use them you can hear water running as you add waste to the toilet bowl. Is this normal? The developer tells me it...
check the type of fill valve that you have in the tank and check with a plumbing shop or better yet check your local lumber company as
they usually carry toilet replacement parts and you can read the instructions on how to adjust the one you have
Sep 22, 2017 | VitrA Aria Toilet with Elongated Bowl/...
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Toilet lid is broken, is there a way to find a replacement
Any normal toilet seat may work, check your local Home Depo.
Mar 23, 2010 | VitrA Aria Toilet with Round Bowl /...
VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - White Logo
159 people viewed this question
Top VitrA Home Experts
jasbo
jasbo
woodzowl307
mrbill99
Level 1 Expert
Are you a VitrA Home Expert? Answer questions, earn points and help others
