Question about Filter Queen Majestic Canister Vacuum
Our daughter plugged it up, in the hose and under the brush,now it has no vacuum.also broke the belt.we replaced the belt,still has no vacuum!!!!!!!!!!!!!!!!!!!
    Genius:
  • 1,036 Answers
A this is a canister style vacuum, Take the hose off completely and check the main unit is sucking correctly.
If it is, then stretch the hose out (maybe with a helper) and see if it blocked. You can usually clear it with a broom or mop handle if it is blocked.
If the blockage is at the power head (which is more likely), take it to an area of good light, and have a look for anything in the centre area - from underneath and from the hose side of things.
It's usually just a case of fishing things out, but sometimes you need scissors for hair or long threads.
Check everything moves by hand before reassembly.
This should solve matters. Thank you for using Fixya.
Posted on Jan 03, 2009
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
I put a new belt on my vacuum and right away it broke
There may be a problem with the brush roller itself. When the belt is removed and you have the brush in your hand, make sure that you can turn it.
If the brush turns fine, what I suggest is put another belt on, and before you close it up, turn the brush with your fingers. The brush should turn. If not, and I have done this myself before too, the belt may have been caught under the brush and not able to turn at that point.
When you get it closed up again too, before plugging it in, give the brush another turn. Just make sure that it is not pinched by the lower housing too.
Good Luck,
Mark
Nov 08, 2010 | Bissell 3576 CleanView II Bagless Upright...
The brush on the bottom of the vacuum won't turn when in position to vacuum. I have cleaned the brush, there is nothing tangled around it.
Sounds like the belt is broke, when you remove the brush, be sure that all teeth are still on the belt and that it is not streched. Typically every major retailer will sell these belts usually 2 to a pack and under $10
Jun 24, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hello! I have an Electrolux Ultralux 2000,
Sounds like the belt on the beater brush has broke.replace the belt on the beater brush.
Dec 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Ive changed the filter and checked the hoses but vacuum doesnt pick up ...when its on the dust is being blown out the bottom of the vacuum....i took the canister off to test the suction its fine...also...
have you check the roller brush and drive belt? It may be your belt has broke or is slipping and therefore not turning the brush.
Turn on machine and power head see if brush is turning if it is put a small amount of pressure on the roller. If it stops turning replace the belt
Nov 18, 2009 | Kenmore Vacuums
Bissell Healthy Home Vacuum brush stopped working. The hose attachment works fine, just the brush on bottom. Without taking it completely apart, it shows no sign of blockage. Any suggestions? Or, will I...
You will have to remove the bottom plate to get at the brush. The drive belt either slipped off or broke, this will have to be replaced.
Nov 08, 2009 | Vacuums
My vacuum has good suction but i can hardly push it across my carpet. any answers????
is your brush roller turning,that would cause it to be hard to push .the brush roller helps it walk across the floor.if your brush roller isn't turning then your belt is broke or the brush itself siezed up.unplug the vacuum and try to turn the brush roller .if it turns real free then your belt is broke.before you replace the belt always clean the motor shaft ,the old rubber from the old belt melts onto the motor shaft .if you don't clean it your new belt won't last very long.please leave feedback
May 04, 2009 | Kenmore Vacuums
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Filter Queen Majestic Canister Vacuum Logo
52 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
